Question about Champion International Garden
I have a cub cadet lt1045 that the belt comes off all the time
I have a cub cadet lt1045 that i bought new in 07. the belt has always come off almost every time i use it. is there a way to fix this.
There is a "tension"spring that hooks to the tension pulley and to the mower deck frame that kept coming loose wich resulted in slinging the belt off almost every time,I used bailing wire to keep the spring in place and it worked.any other questions contact me at dgideon72@yahoo .com
Posted on Aug 09, 2010
The stock settings on this tractor are awful, I ended up chopping the spring down and then using a propane torch I heated it up to make another bend at the end, this added tension. I then also had to adjust the angle that the tensioning bogey, or pulley, spun at. I believe I bent the piece of flatbar metal it rides on to change the angle so that it is lined up better with the p.t.o pulley. Loooots of trial and error.
If you have the snowplow accessory as well I found that I had to tighten the tension all the way on that as well to stop it from folding under a minor amount of snow, now I can take a run at a drift and push it without the blade caving under.
Posted on Jul 18, 2010
As soon as i engage for the mower the belt comes off
THERE IS A TENCHON POLY ON THE BAND SO JUST ULTER THAT
May 19, 2013 | Cub Cadet Garden
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I forgot how i took my drive belt off my mower n i cant put the new one on its a LT1045 built in 04/26/07
I just got on www.cubcadet.com, went to the residental lawn mower section, used the side bar on the left hand side of the screen and clicked on Operators Manuals. its going to bring up a different window; for the model type in: Lt1045- for the serial number, just type in any numbers. after it loads, click on the first operator manual selection you see. after it brings the .pdf file, it should be pg.25 it has the diagram of the belt routeing. i hope this helps, i would have sent u, or loaded it on here, but its copywrited, so, you have to get it on your own. like i said tho...i hope this information helps u. Good Luck :)
Oct 08, 2010 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
241 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
chuck ringwood
chuck ringwood
Dennis Key
Dennis Key
Are you a Champion International Garden Expert? Answer questions, earn points and help others
