Question about Toshiba 36AF42 36" TV
TOSHIBA 36AF42 HAD FIOS AND FIOS BOX INSTALLED AND NOW INTERMITTENTLY THE VOLUME/ON/OFF DOESNT WORK FROM THE FIOS REMOTEOR THE ORIGINAL REMOTE INTERMITTENT. LET SIT FOR A DAY OR EVEN AND HOUR AND REMOTE VOLUME/ON/OFF WORK ON BOTH FIOS REMOTE AND ORIGINAL REMOTE. FIOS REMOTE WORKS ON CHANNEL SEARCH ALL THE TIME BUT THAT WORKS OFF THE FIOS BOX - NOT TV SO i THINK THERE MAY BE A PROBLEM WITH THE REMOTE OPTIC EYE FOR THE TV. THIS STARTED 2 DAYS AFTER FIOS HOOKED UP. TV WORKED FINE PRIOR BUT IT WAS REGULAR CABLE WITH NO CONVERTER BOX AT THAT TIME. IS THERE ANY HELP FOR IT. i ALREADY HAD THE FIOS REMOTE REPLACED BUT NO CHANGE.
  • Anonymous Mar 29, 2008
    THE FIOS BOX WAS REPLACED YESTERDAY WITH SAME RESULTS. KEEP IN MIND THE FIOS BOX DOESNT CONTROL VOLUME/ON/OFF FOR THE TV. THAT WORKS THROUGH THE OPTIC EYE
  • Toshiba Master
  • 19,396 Answers
Your Fios box seems to be faulty
Posted on Mar 29, 2008
  • Ginko
    Ginko Mar 29, 2008
    Your Fios box is probably faulty. disconnect the box in sequence from power outlet and from tv, and cable (there is power which can blow the box in cable). Wait 10 minutes and plug everything together.
    The problem at this point may have temporarily gone, if it comes back in a couple of days, this confirm that the box is faulty.
    If you can get the box replaced as soon as possible.
    Regards
SOURCE:
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
I do not have a remote for the tv but I am hooked up to fios cable system which has its own remote. All things seem to function but I can't change input. All I get when I hit the input button on fios...
The Fios remote work only on the Fios box only as u found that out.U want to control the tv itself,u must have the tv original remote as u used as for like the tv Input button and the tv and other functions of the tv itself.Try website like Remotes.com to buy the tv original remote.
May 09, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Apr 11, 2009 | Toshiba 36AF42 36" TV
Remote control does not work on my Toshiba 36AF42
Try programming the universal remote control specifically for your Toshiba TV, then trying again.
Sep 02, 2017 | Toshiba 36AF42 36" TV
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Jan 14, 2009 | Toshiba MD13N3 13 in. TV/DVD Combo
Volume on tv stopped working
HIT MENU, GO TO AUDIO (SPEAKER PIC) SCROLL DOWN TO "2ND PAGE" AND SELECT SPEAKERS ON. AND YOU MAY NEED TO ALSO SELECT SBS ON
Jul 16, 2008 | Toshiba 36AF42 36" TV
Help pleaseALREADY PURCHASED PREMIUM PLAN?????
The remote receiver IC costs $8 + shipping from andrewselectronics.com
Just fixed this model 2 days ago with the same symptoms.
Mar 30, 2008 | Toshiba 36AF42 36" TV
Remote optic
I HAVE NOT SOLVED THE PROBLEM YET. tHE TECH FROM YESTERDAY SAID TO REPLACE THE fios BOX. i RESPONDED BACK THAT iT WAS ALREADY REPLACED WITH THE SAME RESULTS. mY RESPONSE THIS MORNING IS DO i WANT TO PURCHASE THE PREMIUM PLAN??? I ALREADY DID AND HAVE THE RECIEPT TO PROVE IT??????? IS THIS FOR REAL. PLEASE - I JUST WANT TO GET MY REMOTE TO WORK AT ALL TIMES, NOT INTERMITTENT.
Tom Earles
609-731-1791
Mar 29, 2008 | Toshiba 36AF42 36" TV
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Toshiba 36AF42 36" TV Logo
255 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
