Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have 3 years old ge psw23 refrigerator and evap fan is not working . how to replace fan motor
Amigaman
  • 248 Answers
SOURCE: ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Posted on Nov 14, 2007
  • 121 Answers
SOURCE: ge refrigerator model PDS20MBSAWW
gee seems to me if your are getting the proper voltage witch you say you are sounds to me like a bad condensor fan motor. is the compressor running, maybe shut off because it was to hot.and you are right the motor voltage is from the board. we have had alot of mother board failures on the ge line. but that would be the problem if you were not getting power to the motor.on some models the power comes from the relay /overload hooked to the compressor. if the compressor doesnt come on and you hear a clicking from it every few minutes then you could have a bad
overload and relay that is mounted to the compressor.if thats all good then id say order another motor.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair.com
EMAIL customerservice@allbrandsappliancerepair.com
Posted on Jul 11, 2008
mikedurland
  • 481 Answers
SOURCE: GE GSS 25QF Side by side Refrigerator
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 14, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
fixyourboard
  • 310 Answers
SOURCE: my ge refrigerator ice dispenser wont work and
This sound like the problem described in the following article:
http://www.fixyourboard.com/techzone/refrigerators/ge_fridge_testload/ge_fridge_testload.html
Posted on Jun 20, 2010
Testimonial: "awesome possum got a new board and this fixed the problem thanks"
GE top freezer refrigerator fan rattles constantly
It is mounted properly, it is probably a bad bearing in the fan motor and/or the blade is loose on the shaft. Replace the motor.
Good Luck,
Gil
Feb 28, 2010 | GE PTS25SHS Stainless Steel Top Freezer...
My GE refrigerator is not maintaing cold temp in either frig or freezer
Probabilities:
1. Main board, most likely
2. And/or evap. fan motor less likely.
3. Defrost heater, less likely
4. Evaporator thermister, unlikely, but possible
Try defrosting it for 24 hours (by unplugging) and see if it helps.
GE refrigerator repair orange county, ca
Feb 06, 2010 | GE GSL22JFPBS Side by Side Refrigerator
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer motor making a vibrating sound when running, just started
sound like a bad evap fan but if u replace that u must replace main board and is quite expensive
Mar 18, 2009 | Refrigerators
GE Refrigerator model GSS22WGPH whines loudly!
Sounds like the evap fan motor has a bearing going bad. Best to replace. Easy to for anyone who can use a screw or nut driver to do.
Jan 26, 2009 | GE GSH25JFR Side by Side Refrigerator
Evap fan not working
you must remove baqck panel from bottom of freezer compartment, there you can access fan and other freezer components, check for open defrost thermostat as well.
Mar 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Fa does ot work replaced fan motor fa still does not come on
it's probably the board in behind the cover in back of refrig.it powers the fan. it's a good idea to replace white sensor on evap coil also if your fan didn't come with one
Mar 05, 2008 | GE GSH25JFR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
37 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
