Question about Westinghouse W33001 30 in. HD-Ready LCD Television
The power plug was unplugged and then when plugged back in, power would not come on and the green power light is blinking and no pictur. It is set up with Dish Network and the satelite power seems to be working.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 128 Answers
Check you power supply board
Posted on May 13, 2010
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
Tv power and OPC lights green and blinking, no sound or picture on screen
Crazy as it sounds, try unplugging from wall, waiting 1 minute and plug back in. If set up to network or cable, try unplugging router, cable box, etc, same thing 1 minute and then plug back in.
Referred to as a "soft reset".
May 25, 2016 | Televison & Video
Solid green light but no picture
I think this is a projection set. Sonys are called SXRD type lcd projection . Little diff from DLP types. But they do have a lamp. Unplug set plug back in then turn on . Count blink code. Check lamp also. blink code is 2 digit code. Code will give clue to failure.
Oct 01, 2013 | Sony KDF-E42A10 42 in. LCD Television
I have a Mitsubishi WS-55515 that was unplugged, when It's plugged back in there is power but no picture and green light flashes then the power goes off. For reading other posts I believe it is th
if set has been unplugged plug it in and try to turn on===when power light goes off in seconds:
on the front of the set press and hold both the menu and input buttons for five seconds and release both.
power light will blink a two digit error code like 2 blinks, 2 blinks pause and repeat it several times.
what error code do you find?
Apr 11, 2012 | Televison & Video
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
I turned my t.v. on w/the remote. it came on then turned right off. at least i thought it did. there was no picture and the power light was blinking on and off with a green light. I pushed the power button...
Hello; This problem is likely caused by bad inverter board(s). I think there are 2 on the left side on this model. If either inverter doesn't start, the microcomputer on the main board see's this and generates one "lamp error" . Once it counts 5 lamp errors, the screen will not light and led(s) will flash. These boards are about $100 each and no way to know which is bad. It can also be caused by a bad LCD panel ( cost more than the TV sold for). You can verify a lamp error problem by doing a "forced start" . The set must be unplugged. then"I think" Hold the channel up and volume down buttons on the set or VISa Versa, and plug in without releasing these buttons for several seconds. If the set makes a buzzing noise , the power supply board is bad. If the set comes on and stays or goes off this is the inverter and/ or LCD panel problem. John
Dec 10, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I have one of thos green blinking light and NO
The lamp light would be solid red if the lamp were out. The steady blinking green led is usually caused by failed capacitors on the DM board. You can get the V26 dm repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the capacitors and the CD with detailed instructions.
Jan 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Westinghouse W33001 30 in. HD-Ready LCD Television Logo
90 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
