If this is passed threw a hdmi cable then what you got here is a copy write protection that kicked in (nothing you can do accept buy a WII or a roku box that is allowed to stream to a tv)
As soon as you hook up a hdmi out cable the buck stops right there. The fix is buy a supported settop box or change the cable d-sub 9-15 pins but even in that the netflix program will detect it and disable the video output this is just the nature of copy rights.
I hope this helps/
please do clic kthe accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Ok If this is what happened. How do I fix it because netflicks says you can hook up to your television. What is a WII or a roku box. . Can I fix it myself
Yeah you can hook it up to your TV but not with a computer!!
You use roku.com
if you have a WII you need to ask netflix to send you out a special CD to install on your WII to activate it.
Trust me it can be hooked to a tv but the way your doing it does not even look like it will pass the copyright protection.
if you need more information then that www.netflix.com will be able to answer what devices are supportive of what you need.
Ninntendo Wii is a WII it just captialised the I's on accident.
Hope this helps.
Under www.netflix.com it says watch it on your tv under that i says, Xbox360,Sony ps3, nintendo Wii but also in addendum to that is the Roku box www.roku.com about $100 bucks for that unit.
you cannot just output your video from your computer to your tv the copy right plug in will shut it down.
so you solution is:
Wii
Roku
PS3
Xbox360
look it up you will find all the details you found here on www.netflix.com. It was my pleasure to serve you.
Ok, But I would of liked information that was easier to understand and be able to fix it
