Question about Schwinn 820 P Treadmill Silver Service Delivery
Error code L5 on schwinn 820p - Schwinn 820 P Treadmill Silver Service Delivery
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
Posted on May 19, 2010
What is l5 error
Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:
A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at http://www.sportsmith.net/supportsearch.aspx we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error E5 or L5???
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
What is L5 code on whirlpool calypso model #GVW9959KQ0?
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stops working and the light flashes L5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
KENMORE CALYPSO WASHING MACHINE
Jan 26, 2009 | Washing Machines
Schwinn 820 P Treadmill  Silver Service Delivery Logo
1,313 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
