Question about Gateway FPD1760 17" LCD Monitor
My monitor has started flashing and then the screen will go black but then when I turn it off and turn on and it works, then it will start all over again.
  • 11,361 Answers
You will need to open it up and inspect the inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 13, 2010
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
ViewSonic monitor VS10780
i turn on after 30 sec turn off that happen all the time
Feb 19, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
HP Pavilion - the monitor flashes off and on
Pls uninstall the video card drivers and reinstall them.
Also pls look for any graphics driver updates from the manufacturer.
Also pls check if the cable from the power supply for the graphics is connected on the motherboard.
Pls check with another monitor if it is doing the same thing.
If the same happens with another monitor, then it is an issue with the video card..
Jan 14, 2008 | Computers & Internet
Gateway FPD1760 17" LCD Monitor Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
