Question about Microsoft Xbox 360 Console
Nat setting is retricted how to change it on the xbox360
  • 708 Answers
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports (You will need to contact Modem /Router Manufacturer for this )
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Posted on Aug 12, 2010
My nat type is strict and when i try to play my PS3 i have connection issues. How would i get my nat type to be open?
Zyxel routers don't support Nat 2 confirgurations for the PS3 software. You can fix some issues by powrforwarding the speciffic ports that the PSN uses. To do so follow this ismple guide:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/PlayStation_Network.htm
It may vary from game to game so you should choose what speciffic product are you trying to use here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
Mar 06, 2011 | Zyxel P660HW-D1 Router
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
Xbox360.cant get in to games online.my nat is saying strict,when before it was open
Your IP address may have changed or ports need to be forwarded in your router. Follow this guide from Microsoft to solve the problem:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
Jan 03, 2011 | Activision Guitar Hero Warriors of Rock...
How do you change nat on my xbox360 cause i car'nt
Set Static IP on Xbox 192.168.1.66 (depending on the type and brand of router) Gateway and
- DNS 1 = 2.2.2.2
- DNS2 = 2.2.2.3
Mar 31, 2010 | Computers & Internet
I cant get to the page so i can change my NAT type
mine pops up when i type in www.router.login.net
give that a try.
and heres step by step instructions for changing the Nat type for xbox360 i used to change mine in case you need help.
http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360.
hope this helps
Jan 16, 2010 | Microsoft Xbox 360 Console
NAT settings
The easiest way to fix this is to replace your router.
Here is a list of routers that are Xbox approved
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
The model you mentioned that you have is not on the approved list from Microsoft.
Here is the problem behind your Xbox connection
http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testnat.htm
Jul 25, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Nat type
I have the same router (WRT300N) and this is what I did. I don't know if it will work for more than one Xbox360.
- Go to the Setting of the router.
- Applications & Gaming
- DMZ
. Enable the DMZ
. Choice the Mac Adress under the Destination.
. If you don't know the Mac Adress of your Xbox360 click on the tab: DHCP CLIENT TABLE
.Now from there choice your Xbox360 ( the Xbox360 won't have a Client Name but hopefully you only have your Xbox360 and your computer)
and now save your setting and restart your Xbox360 and there you go NAT open. This also help if you get any kind of  LAG while someone is on the computer using the internet, your Xbox360 will be high priorty to the router.
HOPE THAT HELP
Apr 05, 2008 | Linksys WRT300N Wireless Router
How to Open NAT?
Look for a setting like "Virtual DMZ Host". It's hard to tell for sure without knowing the make and model of your router.
Jan 14, 2008 | Dell TrueMobile 2300 Router (000001)
Nat settings
try going to http://192.168.1.1 default user name and password is admin for both. go to your wireless security and set up security as xbox allows. i think i set mine up with wpa and all i had to do was put the code into the xbox settings after the router page generated an encrypted key sequence.
Nov 13, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Microsoft Xbox 360 Console Logo
14 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
