Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
I think I may have a bad latch on my 4000 series frigidaire Dishwasher. Is this difficult to replace and where can I find this latch. Model #FDBB4365FC1
  • Frigidaire Master
  • 19,396 Answers
Hi.
The door lock switch can be tested either jumping its contacts and cycling the machine, or removing the switch and reading Ohms at switch terminals while operating the switch. This will show if the switch is opening and closing.
The door latch is held to the door by a set of six or eight screws. Disconnect power before starting the repair.
To replace the door lock undo screws, then pull out lock and disconnect the wiring harness connector.
Fit the new lock performing operations in reverse order.
Here the replacement part: I think I may have - _.gif PS2363554 .
Here the door diagram. The switch is part nr.12 in diagram, click on the picture to enlarge.
Regards.
Ginko.
Posted on May 20, 2010
Found an oval rubber gasket in bottom of 4000 series AquaSurge with speedclean dishwasher model PLD4555RFC3. Look to go inside dishwasher but cannot locate where
Hello, Thank You for using FixYa. I will be helping you today.Here is a parts break down of your model CLICK HERE See if you can locate it im not aware of an oval gasket.
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Frigidaire Dishwashers
The door won't close completely
Hi, Check for the following whenever you have problems in door
Latch: The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Apr 12, 2010 | Frigidaire Professional Series 24 in....
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Frigidaire 4000 series dishwasher error code
This is likely an indication of a problem with the circulation pump motor under the dishwasher like maybe a bad circulation pump motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher latch
hi there,
check the door latch and door handle to make sure that there is nothing broken or bent. otherwise, you have to replace the door locking mechanism.
Apr 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
101 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
