Question about Echo Garden
How to fix my echo gt200r gas trimmer I was trimming with it and it got hook on a vine. Then when I engaged the throttle it spun for a second and then stopped, tried a couple more times and it did the same thing. Now it wont spin i thought it might be the gear shaft but im not sure if that is the problem I took off the gear housing assembly but i dont know how to get it apart to see the gear shaft
  • 1,175 Answers
Bill pretty much snswered it...more info if needed good luck.
If the trimmer head doesn't turn, the first place to look for problems is around the head itself. It may be restricted by stringy plant stems and roots -- they may be wound so tightly that you have to cut them off with a knife. It's also possible that the engine isn't developing enough power to spin the head. This could be because either the air filter or the spark arrestor is blocked. Both parts are easy to replace. To access the air filter, unscrew the louvered cover from the intake port. The spark arrestor is just behind the plate that covers the muffler -- you can just pull it out.
Drive Shaft Malfunctions
The drive shaft on straight- and all curved-shaft Weed Eater trimmers is a flexible rod that connects the motor to the trimmer head. This flexible rod can break, and when that happens, the only option is to replace it. A centrifugal clutch connects the drive shaft to the motor. This clutch remains retracted while the motor is idling, but when the engine speeds up, centrifugal force moves it down the engine crankshaft until it engages with the driveshaft. The clutch can stick in the idle position, which usually is the result of dirt buildup and wear in the engine housing.
Separating the Trimmer
To service either the drive shaft or clutch, you must separate the trimmer shaft from the motor housing. It's important to disable the trimmer by removing the spark plug wire from the plug before you begin this procedure, which isn't difficult. The trimmer shaft is connected to the engine housing by two bolts. After unscrewing them with a wrench, pull the shaft away from the trimmer housing. Expose the clutch by removing the screws holding the clutch housing to the engine, and if you need to remove the clutch, unscrew the screws holding it to the flywheel.
Service the Drive Shaft and Clutch
You may need needle-nose pliers to extract the drive shaft from the shaft housing. It's covered with plastic, so even if the wound metal part has broken it will come out as one piece. Consult the Weed Eater website, an online repair service or a local outlet for the proper replacement for your model. If the clutch is stuck, it's possible to clean and lubricate it, but if it has any broken or bent parts, it must be replaced. Reassembly of the clutch and drive shaft assembly is the reverse of disassembly.
Posted on Aug 02, 2017
    Top Expert:
  • Echo Master
  • 48,384 Answers
Remove the head from the shaft( tube) and remove the broken drive cable
get and fit new cable and then reattach the head to the shaft ( tube )
the gears in the head are fairly robust but the drive is a cable which twists up and pulls out of the drive squares at either end
2 Suggested Answers
  • 1545 Answers
SOURCE: Owners Manual for Echo GT200R straight Shaft Gas Trimmer
Maybe go to Echo's website and check with them.
Posted on Jul 13, 2010
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Echo Trimmer starts but won't run
Replace the filter in the gas tank. Sounds like it is mostly plugged.
Jul 10, 2017 | Echo Garden
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
What is the oil gas ratio for the echo gt200r
one gallon of gas/ 3.2 ounce oil (50:1)
Jun 29, 2011 | Echo Garden
Husqvarna vs Echo gas weed trimmers...needing your opinion.
They are very reliable brands stihl is a very good brand also.
Jul 19, 2010 | Husqvarna 28cc Gas Line Trimmer
Open Questions:
Garden Logo
226 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Are you an Echo Garden Expert? Answer questions, earn points and help others
