Question about Numark TTX1 Turntable
I bought two numark ttx usb turntables of ebay with no warranty, they were from the usa. one of the turntables works fine the other did not even turn on at all. i thought it must be that i did't flivk the switch underneath from 110 to 230 volts. i took it in to my local numark dealer for repair and they said i neaded a new transformer. they didnt call me for a month so i went back to them and they said that i need something that comes before the transformer and you cant buy this part because the machines built totally different if there for 230 volts, they told me i'll have to wait untill someone is selling the same machine for parts, can anyone help me at all?
    President:
  • 1,851 Answers
Here is a copy paste from Numark's Quick start owner manual page 3:
3. Voltage Selector:
This switches the internal voltage transformer between 115V, 230V and 240V. The turntable should be shipped with the proper voltage setting for your region. Check that the switch is in the proper voltage before connecting the power cord to prevent damage to the turntable.
At page 2 also there is a diagram showing the exact place for that switch.
So I can't believe that this turntable is stricted for use under 115V. Also, as far as I know from my experience (23 years Electronics Engineer), the only thing that coulg be before the transformer is either the voltage selector switch, or some kind of ac filter. The only case that I'm not sure, is the case that you powered up the turntable at a 230V area and the Numark's voltage selector was set at 115V. In that case the transformer should be burned and the service should replace it and charge you the cost for that.
I think that there is something strange at your case. Why don't you check at another service center at your area?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 13, 2010
How to repair fuse TTX USB Numark Turntables?
If you know it's the fuse, then i assume you are able to remove a push in fuse????? How long do you have the table and did you ever serviced the parts like tonearm , engine etc.... But i assume your push keeps popping out, that's often the end of your powersupply.. greets richard
Jul 14, 2014 | Numark Audio Players & Recorders
My numark ttx deck has started being unable to
Fader has to be ether cleaned or replaced if cleaning did not work.
Nov 17, 2009 | Numark TTX Turntable
Numark TTX-1 turntable starts slow but then is okay.
A drop or two of light oil at the center of the spindle will surely solve the problem.Remove the platter and check if its clean
Jul 06, 2009 | Numark TTX Turntable
I just assembled my numark ttxusb turntable but the stylus was not included
Go back to the dealer you bought the deck from. He is responsible for providing a stylus and fitting it for you.
Jan 18, 2009 | Numark ttUSB Turntable
Numark ttx turntable
More than likely the drive IC (integrated circuit) has shorted, and needs to be replaced. Not an easy fix, and you'll have to take it to a service center for replacement.
This is a common problem on this turntable.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Nov 14, 2008 | Numark TTX1 Turntable
Numark TTX1 Turntable Problem-Platter stops
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
www.djprolab.com
Nov 04, 2008 | Numark TTX1 Turntable
Numark TTX tonearm base repair
Unfortunately, the only way to access the tonearm is through the bottom. It's not that difficult, but you should be very careful when placing your turntable upside down to remove the base.
- OPTiC.
www.djprolab.com
Oct 27, 2008 | Numark TTX1 Turntable
Numark TTX1 Turntable Logo
561 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
