Question about Reddy Kerosene Heater with Thermostat: Multi Fuel Master Torpedo Heater with Thermostat Free Ship
What would cause my 55000 btu heater to keep shutting of on its own? there is plenty of fuel and it will start back up and run a little while and then shut off again.
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
How do I keep the reddy heater 55000 btu working inside the house
Probably has an oxygen sensor so you don't run out of air. Probably not something i would bypass in a house.
Dec 12, 2014 | Reddy Heater-30-55,000 BTU Variable
The heater will run for a few minutes and then shut down
I am going to attempt to list causes (possibilities) for your description:
  1. the hole in the fuel cap is clogged
  2. the fuel filter is restricted
  3. the nozzle is restricted or worn- Desa recommended annual replacement
  4. water in the fuel
  5. the air pump pressure is not set to factory specs - IMPORTANT!
  6. cracked plastic end cover
  7. nozzle adapter cracked
  8. airline or fuel line cracked
  9. defective electronics
  10. defective thermostat or sensor (if equipped)
  11. any reason that will cause the board/photocell not like the flame being produced
  12. motor gets hot- internal heat sensor shuts unit down- replace motor
  13. more than I can list
As you can see there are many possibilities, therefore you must diligently troubleshoot the system. It's not difficult, but you must start eliminating possibilities, starting with checking for proper fuel delivery. Notice I wrote "proper"- too much or too little fuel is a sure shut-down. Follow these tips
Read The principle
Sep 14, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a 55000 btu 2007 multi fuel forced air heater, It started this winter running 15 seconds at a time I changed the fuel but now it will run but you can cut the kerosene fumes with a knife. I have the...
Is there a fuel pressure gauge on it? IF so it be set to the pressure on the nameplate rating. Mine did samething and I had to replace the rubber hoses from the pump to the injector. Your fuel pressure will tell us whats going on.
Dec 14, 2010 | Reddy Heater-30-55,000 BTU Variable
Heater starts and runs but will not go to full force
You can replace the filters ---fuel--- air--- spark plug and vanes in the pump assembly.This is called a fall check up!
Dec 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater has spark but no fuel to ignite it?
the black hose that goes to the back hooks to a pump on back of motor take screws off back and filter clean when back together turn fan by hand and should hear a small vacum at back of motor , not pluged in clean nozzel
Apr 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heating & Cooling
55000 reddyheater
What is the pressure setting on the air pump? The air pump delivers the fuel. the correct pump pressure deluvers the correct ampunt of fuel. Wrong amount of fuel/air ratio produces a stink!
Oct 30, 2008 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
719 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
