Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
I think I may need a new latch. Where can I find this for an older 4000 series model and is it difficult to replace? Model FDBB4365FC1
  • 10,515 Answers
You could buy the Latch from :-
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FDBB4365FC1&productCategoryId=0130000&brandId=1428&brandDescription=FRIGIDAIRE&modelName=DISHWASHER&diagramPageId=00002&componentDescription=DOOR&documentId=R0803219&blt=06
It depends on Person to Person. On an average, i would rate it 6.0 on a scale of 10.0.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 13, 2010
Older model (unknown) Whirlpool Dishwasher. Door latch failure. Dishes trapped inside.
You may have to break the little handle off to open it and order a new door latch mechanism. Just be careful. This is a lip latch so it wont be hard if you can get to where the latch connects. Use the internet and model to order new one.
Jan 23, 2012 | Whirlpool Dishwashers
Tip
How to troubleshoot paper jam problem in printers?
Most common reason are as follows:-- Among the most common problems with any make of printer are paper jams. A printer will jam for any number of reasons: It’s dirty, the wrong paper type is being used, or the rollers on the printer that feed the paper through its pathway are worn down. While cleaning the printer periodically and using the correct paper type are easy fixes, roller replacement can be a difficult job depending on the model of HP printer. For some HP printers, the rollers are easily accessible, but you'll need to completely tear down other models to remove the rollers. Regardless of the cause, when removing a paper jam, always pull the paper in the direction of the paper path, because pulling it backwards can severely damage the printer.
Certain HP printers are more susceptible to paper jams than others. In my experience, any printer that holds the paper vertically and then pulls it down through the printer invariably ends up having paper jam problems. These models aren't designed for heavy use, but many organizations make use of them on individual systems and should be aware of this flaw. In addition, some people have trouble with the newer HP 4000 series printers' paper pickup rollers—which is odd, because the older 4000 and 5000 series HP printers are considered rock solid and don't seem to have any trouble with their pickup rollers.
This will help.good luck.
on Mar 05, 2010 | Office Equipment & Supplies
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Braun 4000 series foils
You must be careful when ordering Braun '4000 Series' foils because Braun has made two different 4000 series shaver types that do not use the same parts. For this reason you must use your full model number or type number to ensure that you select the correct parts. If you are having difficulty locating this number, see video at the link below from shaveroutlet.com
http://shaveroutlet.com/locate_model_number_tutorial/
Once you have found the correct number, you can properly select the correct parts. Below, you will find links to both types of 4000 series foils. Match your number to the list of compatible models on the item pages to select the correct one
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-4700-series-tricontrol-foil-p-349.html
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/foil-fits-braun-4000-series-flex-control-twin-control-p-145.html
Jul 23, 2011 | Braun Health & Beauty
How do I figure out which model I have? I do not have any manuals for my roomba. Currently when I turn it on, it will make a continuous non-increasing circle, then shut itself off.
HI There,
In order to find out which model Roomba you have, turn the machine upside down and look for a sticker that contains the serial and model number.
There are basically 2 different series of Roomba's, the newer 500 series, and the older 4000 series Discovery series. These models usually had multiple buttons on the top, unlike the newer 500 series which have just one.
The older series models included a white, red, green, and yellow colored machines, where as the newer 500 series models have a more sleek design, usually with just a single button in the center. The newer 500 series have colors of black, and silver with different combinations of the two.
Here's a link to pictures of all of the different Roomba series ever made, and the models that they contained:
http://store.irobot.com/shop/index.jsp?categoryId=2174944&cp=2804606&ab=CMS_AccSuper_080309
Also, in terms of the circling problem your Roomba is having, here's a very helpful link that will show you how to fix the "Roomba Circle Dance" as it's been named, haha dancing robotic vacuum cleaners, I just got a mental picture, lol.
http://mysteryroad.blogs.com/photos/roomba_gallery/xintroroomba_3549.html
I really hope this was helpful to you. Please feel free to ask any follow up questions you may have, I'm always more then happy to answer any and all of your questions if this was not able to fix your problem. Please check out our website for all of your Roomba accessories:
http://www.govacuum.com/irobot-roomba-scooba-replacment-parts.html
Thanks so much. If this was helpful, please be so kind and rate my repair helpful, or leave feedback, thanks!
Chris Jones
GoVacuum.com
May 10, 2010 | Vacuums
Nike triax watch strap needed wg48 4000 grey strap
I'm having the same problem with the same model. Were you able to find a replacement strap? Thank you.
Feb 13, 2010 | Nike Oregon Series WA0019-001 Wrist Watch
Cannot get a GPS signal to my 525c DF
This may or may not offer help but on the lowrance site it has very simple step by step instruction to solving this problem. The first step is to make sure your getting power to the new 4000 series. With a 12v tester you can do this. On the gps unit there is 3 different power sources. One is main power, two is sonar and three is power to data. One you have power going to the 4000 then proceed to other options. I hope you didnt pay full price for your 4000. Lowrance has a replacement process and replaced my 2000 for a 4000 for $120 (2 day shipping). Back to your situation... Out the back of the data will the a cord that connects into the bottom of the T, and the a resistor on one side and the 4000 on the other side.
Nov 11, 2009 | Lowrance Lms 525c Df 5" Df Sonar...
I do not get the door lock indication on my maytage neptune frontloader washer, which prevents the high speed spin.
what model is it if its the 3000 or 4000 u have to replace lock latch and top board not worth fixing if its thee 5500 model just the locklatch and its worth fixing
May 20, 2009 | Maytag Neptune Washer
I need to fix a power supply. HP or agilent part number 5061-3375. Thanks Kevin edmundsk@bsci.com
It might be better to replace the machine with a laserjet 4000 much better machine and higher DPI 1200DPI in fact, however go to www.printerworks.com for help, they might sorce you a power supply other wise get yourself a laserjet 4000. much better model.
I think the laserjet III series and its variants are going to the tooth now.
Apr 29, 2008 | HP Refurbished LaserJet IIISi printer...
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
