Question about Craftsman 24 Hp 48" Deck Yard Tractor
How to replace belt on a ford 930a finish mower
Tip
Replacing Riding Lawnmower Blade Belts.
I discovered on a Craftman Riding 3 bladed mower that there is an easy way to replace the belt for the blade pulleys.
The mandrel cover of the Left side blade is the only part you need to remove to replace the belt. You can insert the belt under the right side mandrel cover and onto the clutch pulley before finishing on the left side of the mower.
The tensioner or idler pulleys will contract when you pull on the belt. When you get to the left blade pulley you can turn the pulley with one hand and guide the belt with the other hand. The belt will walk right up onto the pulley. Attach the cover and you're done.
I like my method because you can stay away from a hot engine and replace the belt without waiting for the motor to cool off. You are also not fighting the mower clutch or drivebelt with my method.
on Dec 16, 2010 | Garden
Need instructions how to put on and route a mower 42 deck huskee lt 4200
here is a diagram from the internet, hope it helps.
May 15, 2016 | Garden
How to replace belt on woods rm660 finish mower
not sure about the 660 for sure but normally the woods mowers have a tensioning wheel that keep the belt tight when it is running and if you depress the wheel it should allow you to remove the old belt and put on the new one. Take a look and see if one of you pulleys has a spring attached to it and if so that is the tensioning wheel.
May 08, 2015 | Woods Garden
How to replace belt
SWISHER 44 Finish Cut Trailmower Tension assembly belt bra Parts Model...
If you look at the diagram ( zoom in) part #94 , idler spring, is what puts tension on the belt.
Jun 07, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
Replace idler arm on craftsman tractor
It is not easy. You need to remove the mower deck.Take lots of pictures while doing this repair. It has to go back exactly right with
no left over parts. Replace the spring cable at the same time. Pay particular attention to the routing of the belts. If you don't get the mower belt put back correctly you will smell your $30 belt self
destructing. Pay attention to where the various washers go while
putting on that new arm. Make sure the new cable is away from anything that can damage it. Everything in that area is sharp. You will
most likely be bleeding and swearing when you are finished.
May 19, 2014 | Craftsman Garden
I need a belt diagram for a Landpride 6' finish mower.
Check out their website and look under manuals. http://www.landpride.com/main_products/main_gm.html
If you don't find it there, I'm sure customer service could hook you up...
May 28, 2009 | RTO Farm Pro Finish Mower 5' Rear...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
940 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
