Question about Logitech QuickCam Express Web Camera
Software problem? When I plug in the device it doesn't show up in My Computer. It worked fine last time I used it...not sure if I need to install the software to my new computer or not?
  • 31 Answers
YEAH u have to reinstall the driver and the software again
Posted on May 13, 2010
I am using acer e725 , emachine i have windows 7 installed; previously with same oeprating system and drivers my webcam was running fine but now for last one month it is showing black screen mreover w
Plug the webcam into a different computer to check if it still works. If it works, uninstall any webcam software. Then plug the webcam back into your e725.
Oct 05, 2014 | Porter Case PC II AVCS Projector Case was...
No video device detected on my system
if you are using laptop it should be have a function button (fn) with a camera like in somewhere in your keyboard..turn it on.
if it doesn't work right click My computer > properties > a new window will pop up and look for device manager. make sure you have installed the driver for your camera.. or if it is plug-in make sure it is installed corectly..
be sure that your device is on good situation.. hope this help...
Sep 25, 2011 | Acer Crystal Eye webcam
Alright so I have a Logitech webcam C160 and I've used it plenty of times now and I've taken good care of it. The problem is when I plug it in and go to use it, the green light flashes then turns...
I would go to control panel, bring up devices, and attempt to rollback driver, reboot and test. If this did not work, verify there are not two drivers assigned to port - open device manager again off System, then check device drivers. if two - remove the second one. If still does not work remove all drivers, uninstall all software through the add/remove programs, remove device, install software, plug in device, then reboot again.
Jun 13, 2011 | Computers & Internet
When hd is plugged in, it installs device and drivers automatically. it never shows up under my computer but in the taskbar it shows safely remove hardware. power light shows orange but harddrive light...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Nov 14, 2010 | Seagate (9W2063500) 120 GB Hard Drive
My 4 GB V30 Transcend pendrive is not getting detected in any OS (linux and windows 7). In windows its saying that driver software installation failed. And in device manager its coming as unknown device....
try to open in another computer see if it opens there n get ur data first coming to the unknown device issue, firstly insert ur pendrive to usb slot firmly then refresh your comp for about 5 times wait till the drivers are installed open "my computer" n see if the pendrive icon is displayed if its displayed double click n start using . If the above procedure does not work first time do repeat it ur pendrive will work for sure
Sep 20, 2010 | Transcend (589307) Media
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
My Laptop won't register new devices
This is just a software issue. There might be uncompatible software installed in your computer or malware. 1st thing try to disable your computer's start up (remove all the driver software you installed for new devices) then restart your computer.
2. Connect 1 device then install the driver.
** if still not working need to perform windows system restore. You can choose the desired restore point or the last time you were able to use your computer normally.
procedure: vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
**If still not working, you need to perform Factory recovery or set everything back to factory default. or use the recovery disk.
Note: before doing any Troubleshooting in your make sure that you have back up for your important files or image for the programs that you have.
Mar 30, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
After replacing the harddrive in my computer, my speakers no longer work. Under Control Panel, Sound, I get mesaage "no sound deice installed" In device manager, I have several sound devices installed all...
You need to unplug speakers if plugged in. Install the software and drivers for your Speakers. Then plug them in and you should be able to use them. If this doesn't work, go to device manager remove all USB devices, and reboot, then re-install software & driver. Then plug in ya speakers. They should work.
Jan 26, 2010 | Altec Lansing AVS 300 Computer Speakers
I can't install my logitech pro9000
Remove the driver from device manager and uninstall the software. I would also check in the registry for any files and delete them. Then reboot and try to install again. Make sure not to plug in the webcam until the software prompts you to.
Feb 26, 2009 | Logitech QuickCam Pro 9000 Web Cam
Firelite 160gb HD not recognized
Make sure that there is no "HD protection", in which the hard drive can only be connected to one computer. Also, try going to google and searching for some drivers for your computer to download and install. Then try plugging your hard drive in again.
Dec 28, 2007 | FireLite (USBFLB80) Hard Drive
Logitech QuickCam Express Web Camera Logo
23 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
