Question about HP Officejet 7210 All-In-One InkJet Printer
Printer is installed, but when document goes to queue...it says error printing or error sent to printer...help!!!
    Brigadier General:
  • 4,090 Answers
Check that the cable is connected securely and not skewed
Please rate my help++++Thansk for using FIXYA
Posted on May 13, 2010
Document sent to printer doesn't show up in print queue. Test page goes to queue, but gets "error printing". Troubleshooter doesn't find anything. Driver is newly installed. What can I do to fix?
Is the printer selected on your computer?
Is it plugged in and switched on at the power point?
Is the printer turned on at the printer?
Does the light come on on the printer?
If all the above happens then :
Look up changeing printers in "help".
Because you did not give any information about your computer operating system I can not give any further details.
Feb 23, 2016 | Epson Stylus CX8400 Series
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows)
a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
Dec 28, 2013 | HP LaserJet 5200 Printer
A document was sent to the 5110cn color printer. it is a full color duakl sided brochure. Keeps trying to print but errors out before loading all images so all that gets printed is one or two of the...
The reaason it keeps trying to print is because it's in the print queue on your network.
Have whoever sent this to the printer open the print queue and delete it.
Only the originator or the print queue admin can delete the job
Jan 06, 2011 | Dell 5110cn Laser Printer
When I click print the document goes into queue then when I troubleshoot it says the printer wont print because a document is in queue. When I clear all documents it says "printer ready" but then it says...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 18, 2010 | Epson Office Equipment & Supplies
Cant print using Dell A920 printer on my imac. printer set up shows driver is correct I think and the printer name is correct.
So clearly the Macintosh sees and recognizes the printer. WIll it let you queue a document to the printer? After you do, you will see an extra icon on the Dock that represents the printer queue. Open it up and see what is happening to the printer job. If it disappears, it was sent to the printer and the Mac thinks it was printer successfully; if it isn't printed then you have either a bad printer or a bad printer driver. If it stays in the queue and goes to "hold" state, look in the log to see what the error was -- the Mac is unable to negotiate with the printer to get your file printed.
Jun 09, 2010 | Apple iMac G5 Desktop
DOCUMENTS FOR PRINTING DON'T GO INTO A PRINT QUEUE
If you mean that when you go to print a document it doesn't hang in the Windows print queue and leaves quickly, then it is because either the printer has grabbed the document into its memory or it has sent the document to what it thinks it another printer. It might also be that the drivers you are using are not set correctly or that the connection to the printer is incorrect.
Jul 09, 2009 | Lexmark E232 Laser Printer
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Canon 4150 wont print , goes into queue
Have you gone into the queue and deleted the print jobs and started again? Do you have any error lights? If so there could be a hardware problem with the printer.
Try taking out the toner and putting it back in. Sometimes that will force the printer to reset intself.
If that doesn't help then you may have to delete the printer from the system and re-install it.
Apr 13, 2009 | Computers & Internet
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
