Question about Mitsubishi VS-50703 50" Rear Projection Television
RE: Mitsubishi VS-50703 50 in.\r\nUpon turning on
RE: Mitsubishi VS-50703 50 in. Upon turning on the TV and the cable box it appears that the TV changes channels from 3 and we get black and white static with noise. Then we have to change TV channel back to to 3 to see picture. Any ideas as to why this happens every time we turn on TV/Cable box?
  • pgamwell May 13, 2010
    that worked thanks
  • 11,896 Answers
Go to settings, then tuner or channel edit, make sure tv is on CATV for cable or AIR if you are using regular tv. Sounds like you are using cable or satelite, so choose CATV, then choose autoprogram and the tv will scan and remember all available channels and store them for you.
Posted on May 13, 2010
    While TV is off, the green power light flashes slowly on and off. Any idea why?
  • Nate Stansfield
    Nate Stansfield May 13, 2010
    Not a problem. Thank You for using Fixya!
How do I connect my time warner box to the dtv input on my 2001 MITSUBISHI 1080P HD TV
You need the proper cables. I would call your local cable office and ask them. You will need the model # off your TV. 2001 mitsubishi 1080P HD TV is not the model. The model will start with VS. It is located on the rear of the TV.
Feb 28, 2015 | Mitsubishi Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-5003R close caption
That is so old I can't find specs on it.If you have a cable box, Directv or Dish Network you can turn on cc from the Receiver box or even an antenna converter box
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Vs-50605 HD Ready Mitsubishi 50"
with the age of this set it is probably component input for the hd,,remember 480p is considered hi def..
Nov 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-5051
It is called Text in your Close Caption. Turn off
Nov 12, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-45609
You should have two antenna inputs A & B. Most commonly the RF or TV output on the back of the cable box is connected to antenna A and the TV has to be set for channel 3 or 4 depending on which station is not available in your area. If you don't get a picture on 3 or 4 then switch the cable box to antenna B or find the switch on the remote that allows you to remotly switch antenna inputs. If your TV has a connection that says "cable out" don't use that one as that is for a more complex setup. I hope this helps you.
May 02, 2007 | Mitsubishi VS-45609 TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
