Question about Mitsubishi WS-65809 65" Rear Projection Television
My rear projection tv is blurry and after i adjust the convergence, it goes back blurry again and i start over.
  • 1,476 Answers
You have defective convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 13, 2010
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
THE PICTURE GET BLURRY FOR A FEW SECOND THEN GOES BACK TO REGULAR..IT IS A 55 INCH MITSUBISHI TV REAR PROJECTION...IS TIS EXPENSIVE TO FIX?
Yes,the shop will cost u $300 for parts and labors. Convergence problems,the 2 convergence ICS it well die,just not dead yet.Problems will be blurry,color misalign,3 D look,when the 2 convergence is dead.
Feb 06, 2010 | Televison & Video
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
When I turn on my rear projection tv the picture is fine, then all of a sudden it goes blurry, after about 45min you turn it off and then back on and the picture is fine. what could the problem be. the...
well if your tv was to be a normal tube tv, i could suggest to check your crt socket. in this case its projestion tv, so your are having three crt sockets. the main problem is with your main flyback transfomer. try to change the flyback and it should work back to normal. other way to test is try to adjust your transfomers focus, if it is adjusted, and goes blury again, then you need to change it,...and try to re-service the board...best luck
Oct 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a sony 60 inc rear projection lcd. the tv turns on ok, however, the picture and sound goes off and then comes on again. this happens every 15 minutes or so.
hello do these checks first Adjust the Picture setting in the Video menu (see page 49).
❏ Adjust the Brightness setting in the Video menu (see page 49).
❏ Check antenna/cable connections.
❏ Adjust the convergence again using FLASH FOCUS (see “Adjusting the
Convergence Automatically – FLASH FOCUS™ –” on page 33). if this don't work get back to me and we'll try somethink else thanks
shaun
Oct 13, 2009 | Sony KP-57WS500 57" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Hitachi 57F500 blurry picture
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
Mar 18, 2009 | Hitachi 57F500 57" Rear Projection...
Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
Jan 14, 2009 | Toshiba 50H82 50" Rear Projection...
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WS-65809 65" Rear Projection Television Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
