Question about Bryant Heating & Cooling
My unit stays on even after shutting it off or turning it down. I replaced the thermastat and the problem still acurres. HELP!
  • Brian Niten May 13, 2010
    Does the indoor fan continue to run? Have you looked at the contactor in the outside unit to see if it is open? Does it ever shutdown?
    Problem Solver:
  • 17 Answers
Have you used the weed eater out by the condensing unit could be short in thermostat control wiring to outside unit or a stuck contactor in condenser control circuit try these first then if not there in furnace control circuit at board that jockeys between air and heat remove thermostat wires from board remember thier location bet it stops.
Posted on May 13, 2010
Have a braebum 3000 funice stays on for couple sec.then shuts off turned heat up to 78 but thermastat wont go past 68 it cold
I would check the flame sensor is clean also check air filter you could turn off the power to the unit and see if it resets it self .
Dec 08, 2016 | Heating & Cooling
Condenser fan on heat pump does not turn off
If it is just the condenser fan that means you have a fan relay that has welded shut. Turn power off to your unit and trace the wires from your condenser fan back into the control panel at the unit. You'll have 3 wires going to it. 2 go to the run capacitor and one goes to the fan relay. The one that goes to the fan relay is the part that needs to be replaced. If you have no fan relay and it goes to the main contractor, half of your main contractor is welded shut and will need to be replaced.
Sep 18, 2014 | Carrier 52PQ-515---3 Premier Series Heat...
Can't turn one unit off when I turn the volume allthe way down I get no click and the unit stays on
Unfortunately, your volume potentiometer (the part behind your volume knob, which connects to the component board, has gone bad. This can happen from turning the knob too far past full volume or even sometimes when turning it off. The part to repair this has never been offered as a replacement part. Your only solution is to remove the battery to turn the unit off.
Best regards.
Dec 07, 2012 | Motorola Talkabout FR60 (14 Channels)...
I cant get my temperture controll buttons to raise thre temperture
could be a problem with your thermastat ,shut it down for a while all the way then turn it on and see if that helps, only turn your unit up in small increments till you reach the desired temp.
Oct 16, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
I have a GMP100 furnace and I replaced the control board because the blower fan wouldn't kick off now and then. It all works great but the main blower only stays on about 45 seconds after the burner turns...
Check the board for a set of dip switches. Check against the old board for switch positioning. These control fan on/off times. Ensure you turn power off before changing switch positions. If no dip switches,??
Dec 04, 2009 | Refrigerators
Fireplace will not stay lit and pilot light is on
This sounds like the high temperature switch has failed and is telling the unit to shut down after it gets started, the pilot has to be lit for the main gas valve to turn on when the thermostat calls for heat, The main burner comes on and stays on until the thermostat is satisfied and tells it to shut off, you dont say if there is a blower in this unit, if there is a blower after the main flame comes on the unit heats up it turns on the blower if equiped. If the blower fails to turn on the unit would be shut down on overtemp as the firebox would get to hot and be in danger of causeing a fire. if no blower there still is an overtemp switch that shuts the unit down if it gets to hot or the switch is bad, it could be a bad overtemp switch or if equiped a bad blower motor or even a plugged chimney as this would also cause a overheat ing condition. Hope This Helps Don
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Unit will try three times to start then shut down
Make sure the exhaust fan is running.You say it fires up and then cut off.Does the main burner come on just the pilot?If it's just the pilot then I would say you need to replace sense that senser the pilot lite.Because onces that senser the flame the main gas vavle should open.for give me for my mis spelling.
Mar 26, 2009 | Heating & Cooling
Heating & Cooling Logo
98 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
