Question about LG VX8300 Cellular Phone
My bluetooth will not work it says pairing failed to everyone
Yes i need to know what i can do to get my bluetooth to work ? i have an LG phone and it also will not let me view my recieved picture messages it says access restricted can u please help me
I accidently locked my cell phone and can't find my LG cell phone manual book to look up the factory set code to unlock my cell phone
Posted on Mar 29, 2008
I have sony erricson ds220 bluetooth headset. It was paired to Nokia E5 phone and it was working fine. I lost E5 phone and have bought a new LG phone and headset is not able to connect (discover when i...
Phone: Turn on Bluetooth and Bluetooth visibility. Keep it close to the headset (20 cm).2. Headset: Switch it off. Press and hold down the on/off key until the pairing icon appears on the display.3. Phone: If your phone supports auto pairing, press YES when Add device? appears to complete the procedure. If not, continue with the next step.4. Phone: Follow the applicable User guide to pair with a Bluetooth headset. You may need to enter a headset passcode (0000).
Oct 25, 2017 | Sony Ericsson HBH-DS220 Wireless Headset
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
Im trying to pair my bluetooth to my metropcs lg
yes the default bluetooth code is 0000
May 16, 2010 | Cell Phones
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
I can't connect my hbm-210 bluetooth to my
Go into your phone and under your bluetooth settings delete your headset profile. You can now just go through the pairing procedure again and your phone should find the headset and you can click yes pair with this device(headset) and just finnish you pairing. Also make sure you didn't turn your bluetooth power off on your phone by accident.
Jan 28, 2010 | LG Cell Phones
Can the LG HBM 550 be paired a second time to another phone?
YES IT SHOULD BE ABLE TO BE PAIRED TO AS MANY PHONES AS YOU WANT BUT WILL ONLY WORK ON ONE AT A TIME.
Sep 16, 2009 | LG HBM-550 Wireless Headset
Lg env2/ jabra vbt85z bluetooth pairing
You will have to go in and reconnect it. When it says allow, be sure to push yes. You may have accidently turned of the internal connection in your phone. Go to bluetooth menu in your phone, click the bluetooth that is yours, and click connect. I did that once, and this fixed my problem. I dont think you can have it paired to more than one phone at a time. It wont know which one to answer. Good luck.
Nov 08, 2008 | Nokia 1600 Cellular Phone
Pairing LG Shine and Bluetooth HS850 unsuccessful
UGH I had such a hard time with this, because it isn't clearly explained.
So here is a solution that should work (it worked for me!):
1. Go to Settings, Bluetooth, and Go to the "Paired Device" menu and leave it open.When it asks to turn BT on, you can do so.
2. This is the part here that screws everyone up. Take the headset and press and hold the multifunction button. KEEP IT HELD DOWN! The light should turn on and stay on. While you are holding it, open the microphone. The light should have been on while you were doing this and still be on. If it didn't stay on the whole way try again from when the mic is closed.
3. Remember the "paired device" menu? Select "New" and it will auto search for the headset.
4. It should be found quickly. The headset (that you should still be holding down but with mic open) will blink, then your phone will ask if you want to pair with Motorola HS850. Say ok, then it will ask for passcode 0000.
5. The headset will blink and the phone will say it was successful, and ask if you want it to be turned on. Say yes and make a test call. It should be fine from there.
Hope it helps!
Feb 15, 2008 | LG Shine KE970 Cellular Phone
Blue Tooth Stereo Headphones and KRZR
From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support.
There is no solution
If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine.
I am going to the Verizon store to complain untill i get a different model.
In short the KRZR software is defective
Dec 26, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
LG VX8300 Cellular Phone Logo
111 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
