Question about Kenmore 800 7983 Dryer
Dryer runs but doesnt get hot
Im trying to reset the breaker or change the fuse cant locate them
  • Kenmore Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer runs but doesnt get hot - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Drdryer runs but doesnt get hot - 2_bing.gifc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrdryer runs but doesnt get hot - 2_bing.gifthis problem...
Dryer2_bindryer runs but doesnt get hot - 2_bing.gifss= Troubleshooting2_bing.gif Edryer runs but doesnt get hot - 2_bing.gifg src="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 15, 2010
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
Whirlpool electric dryer not running.
Check the blown fuses and home's circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Dryers
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Jul 02, 2010 | Kenmore 63942 Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Where is the 30 amp fuses located?
in your fuse panel for the house. try turning the breaker off then back on. even though the breaker doesnt look tripped , one side could be tripped and not trip the whole breaker. If you have 2 thirty amp screw in fuses in your panel just replace them both.
Dec 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
What does it mean if my roper dryer runs but doesnt get hot ?
either the breaker has tripped and not allowing it to heat,thermal fuse kit may have gone bad or element is bad.that is normal problems with dryers.first check to see if 220 is going to dryer and drye cord is in good shape.no burns.
Mar 10, 2009 | Roper REX4634KQ Electric Dryer
Kenmore 80 series wont start
Common failure of these dryers is the door switch. The switch is located at the top right where the door comes in contact with the tab,
A simple test is to verify that the light is on and goes out when the switch tab is depressed.
If not replace the switch.
Hope this helps?
May 24, 2017 | Kenmore 64892 Electric Dryer
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore 800 7983 Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
