Question about Imperial IFS40 Deep Fryer
Soot build up
I have a imperial ifs-40 that i get alot of black soot on my walls of my stand and in the fryer. people tell my im not getting enough air if so how do i adjust it
  • Anonymous Mar 26, 2014
    weak flame that builds up black soot
  • brad27511 Jun 14, 2014
    there is a sloted metal ring that allows you to change the amount of air that gets mixed with the gas. You could also have the wrong sized orfice in the burner, a brass fitting with a small hole. They are different size holes for LP and Nateral gas. Find the manual online and look for the type of gas you are using. There will be a "lettered" drill bit size shown for the burner BTU output. The orfice might of been replaced and wrong size put in when chaning the type of Gas you now have. "Lettered" (a-z) drill bits are somewhat hard to locate.
    Problem Solver:
  • 11 Answers
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
Posted on May 13, 2010
Black soot
Soot is caused by a few things in gas appliances. Propane even more so. Lack of combustion air is usually the culprit. In propane fired equipment orifice alignment, high pressure or the wrong burner orifice can cause yellow flames the result in soot build up. You need to find the culprit. Best to have a service tech check it out and clean it. when you know what to look for it can be easily fixed.
Mar 26, 2014 | Imperial IFS40 Deep Fryer
Deep fryer ignites but burner flames will not enter cylinders
Hi there.
Fire tubes may be clogged with soot. Have a technician inspect and clean the fire tubes for soot deposits/ build ups.
Check also if there is no air or ventilation directed on flue as it will push the flames back to the burners.
Regards.
Aug 12, 2013 | DCS Gas Deep Fryer 40 Lbs Double Basket...
Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Apr 27, 2013 | Kitchen Appliances - Others
My flame is burning yellow and there is no pressure. Can you tell me what I can check?
The burner is blocked need cleaning/ the air ports to the burner are blocked lack of air causing yellow flame and soot
Needs a service asap.
May 15, 2012 | Imperial IFS40 Deep Fryer
My Fryer Gives off a lot of Soot
Sounds like you may have the thermostat turned way too high.... If you don't, check to make sure it's working correctly, like is the temperature reading correct? Is your flue all junked up with build up and crud? If so, you will need to clean it out.... You can scrap it out with a dough scraper or anything else that works for you...Also, you might check your gas connections, or have your gas co check them, and see if there are any issues with the gas connection and the amount of gas coming into your fryer. Hope this helps you.
Susan
REO
Dec 03, 2011 | Imperial IFS40 Deep Fryer
My fryer burns with alot of black soot
you need to clean the burners and the fire tubes, remove all carbon deposits.running the unit on low gas pressure results in carbon build up on burners and fire tubes.
Mar 11, 2011 | Pitco Frialator Kitchen Appliances -...
My imperial IFS-40 is burning the door
Is this fryer propane?It sounds like the baffles in the tank are clogged.If you remove a burner shine a light in the baffle,if you see alot of soot use a shop vac and clean it out.Let me know.
Apr 23, 2009 | Imperial IFS40 Deep Fryer
One burner puts out soot.
the buRner that puts out soot need to be adjusted down a bit!
Nov 24, 2008 | Imperial IFS40 Deep Fryer
Recovery time
If the unit starts off fine, and then loses some of it's heat, I would suspect that your regulator is freezing up. This can be caused be a bad tank or regulator. You'll have to swap it out to test it.
If the gas supply is good (reg and tank), you need to inspect the heat exchange tubes. Look where the flame shoots through the fryer. Use a flashlight. Look for LARGE amounts of black soot. If it is sooty, blow it out with compressed air. Once you get it cleaned out, you need to add more air to your mix. There should be a disk at the base of the burner.
If you have access to a manometer and orifice drills, you could adjust the flame to it's maximum. But as I said, I expect you have a regulator problem.
May 29, 2008 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
832 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
Dan Webster
Dan Webster
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
