Question about Mtd 22" Yard Machine Push Mower
Briggs & Stratton 6hp yard machine with 21inch cut. Not getting fuel. I replaced a bad fuel line and now no fuel! If I take the air filter off and spray fuel into the carb it runs until I quit.
    President:
  • 1,033 Answers
The fuel bowl needs to be removed and a new float and needle needs to be installed. The float "floats" in the gas bowl raising the needle, letting fuel into the carb. The repair kit cost about $5 and easily replaced. The float is attached with a pin and the needle fits on the float.
Posted on May 13, 2010
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
Manual
run with gas treatment like gumout and fuel stabilizer like seafoam to rid of ethanol and replace plug and air filter ..is it a briggs and stratton ?
Jul 27, 2013 | Mtd 22" Yard Machine Push Mower
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
It only runs in choke!!! Help!!!
Most likely causes: dirty, clogged air filter; or dirty, clogged fuel line filter. Check 'em out, replace if dirty.
Aug 16, 2010 | Yard Machines 155 Torque Briggs Stratton...
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
127 cc briggs and stratton engine starting problems
  1. A few things, some you may have already looked at so if you have great.
  2. Fouled Spark Plug. Check, clean or replace.
  3. Clogged Air Filter, Check, clean or replace.
  4. Fuel, check fuel screen/filter, fuel lines for damage, wear, blockage lines get weak with age and colapse cutting of fuel supply.
  5. Linkage, check choke linkage intact and working freely.
  6. Check carberator float making sure that it's operating freely.
I hope that the list of checks help you. Thanx for using fixya, good luck and a good week. Jeff
Apr 05, 2010 | Briggs Stratton 10,000- to 12,000-Watt...
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Describe your Briggs & Stratton
you need to rebuild carb and check groverner spring
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
20 hp briggs and stratton revs up and down
lower throttle and if that doesnt solve it check the governor might be broke
Jun 24, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mtd 22" Yard Machine Push Mower Logo
1,006 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
