Question about Seal U.S. Mfg. Ps 201 Replacement Pump Shaft
My ps 201 shaft seal keeps keeps ripping do you have an answer why
  • 990 Answers
Check the face of your motor for corrosition. The front end of the motor is aluiminun and as the seal leaks the corrosition will build and warp the seal plate causing the seal to run crooked.
Their can be other reasons but this is the most common.
Posted on May 13, 2010
Front diff.seal leaks
Remove the front drive shaft remove the drive yoke off the pinion shaft remove the old seal install new seal install front drive shaft. PS check pinion bearing play before removing drive yolk. if it is loose then you might also need bearings
Oct 21, 2015 | Ford Explorer Cars & Trucks
Where can I get rebuild kit for the pump of my Aker swirlbath model CT26060B0? The seal is leaking at motor shaft end of pump.
That is great, that you posted a picture of the motor....
but unfortunately the motor does not have a seal. It is the wet end that is connected to the motor which makes a pump, and that has the mechanical shaft seal.
if you remove the cover of the wet end, and expose the impeller, then remove the impeller, and expose the shaft seal, we would be able to assist you better. A picture of the wet end and post it, will greatly assist as well.
unfortunately the information that you provided, although very much appreciated, really does not assist. Because the manufacturer of the tub, can use a variety of different vendors for the pump. But,...
if your tub came with a serial number? You can contact the manufacturer and they may have records as to what pump was used on your specific unit. And then from there you would be able to know what pump or more specifically...which Wet End, was used and then you would be able to find out which mechanical shaft seal went into that pump or Wet End!
if I was to venture a guess: it is either a
U.S. Seal PS 200 or PS 201
Mar 28, 2015 | Pool & Spa
Install dryer door seal
That is a simple dryer door seal. Remove the old one by simply getting it started...normally at the bottom of the door will be the seal when the door seal starts and ends. Grab one end and pull hard. If it rips, don't worry....you are installing a new seal. Once you have the first tab out, make a mark with a magic marker and then continue to remove the old gasket by pulling and wiggiling. Start he new gasket at your magic marker mark and simply continue to press in the slotted tabs until complete. If I can help further.....
Waiting to hear from you,
Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
May 19, 2014 | Whirlpool Dryers
Asembaley
Instructions usually come with the seal kit. The tricky part is getting the impeller off without damaging it. There is a flat on the other end, not easy to get at. Then it's just a matter of carefully removing the old seal and setting in the new one, cleaning the place where it goes.
Nov 22, 2013 | Seal U.S. Mfg. Ps 201 Replacement Pump...
I'm trying to find a seal kit for a Emerson spa pump Model #T55MWCCE-1208
The seals are specific to the Jacuzzi pump housing not to the Emerson motor. Most Jacuzzi pumps use the PS-200 or PS-201 seal (some have it listed as AS-20X) here is a Pump Seal Cross Reference.
Jul 25, 2012 | Emerson Pool & Spa
LEAKING A SMALL AMOUNT OF WATER COULD THIS BE A SEAL?
ON A HAYWARD IT'S A TOSS UP, COULD BE THE SHAFT SEAL OR THE TANKS ARE KNOW FOR CRACKING. FIRST THING YOU CAN TRY IS REPLACING THE SHAFT SEAL .. LOOK ON EBAY FOR HAYWARD SHAFT SEAL WITH HOW 2. THE SEAL YOU NEED IS A 201. AND SHOULD COST AROUND 10 BUCKS. FALLOW THE INSTALL INSTRUCTIONS. OR YOU CAN TAKE THE PUMP APART AS FALLOW HERE ..AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY .. JAY
Jun 17, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a steady small stream of water from the bottom center of my pump. A seal for sure, but I've never had the motor off of the pump. Can you describe the operation and the most likely seal that I...
here is how to remove your pump click here the seal is a 201 search ebay for it there is one that a guy is selling that has a how 2 replace it for around 10 bucks. these pumps are known for cracking, but if you say its leaking from the center, sounds like a 201 hayward shaft seal. PRIME THE PUMP AFTER ANY REPAIR !!!
Jun 02, 2011 | Hayward 1 Hp Super Pump Inground Swimming...
How do you replace a seal on a Sta-Rite pool pump? How do you remove the old seal? Ceramic and graphite.
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Aug 14, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Us seal ps-200 pump seal installation. What direction does it go?
Thank you for posting your question here on Fixya.com.
Shiny carbon (black) face rides against shiny white (ceramic) face. Rubber boot around ceramic face sits in the pump recess to seal ceramic into recess. Do NOT touch the polished carbon or ceramic faces with your bare hands. Use a cloth or the cardboard disks to press the ceramic into place. Use a synthetic lube or water to 'grease' the fit to allow for easier installation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 03, 2010 | Seal U.S. Mfg. Ps 200 Replacement Pump...
Seal U.S.  Mfg. Ps 201 Replacement Pump Shaft Logo
128 people viewed this question
Top Seal Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Seal Pool and Spa Expert? Answer questions, earn points and help others
