Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
Noisy dishwasher My three year old dishwasher is very loud.This problem has been going on for almost a year now.The dishes end up clean but the noise is very irratating. It always happens during the wash cycle.Can you help?
I have the same problem. I have been checking around on the internet, and it seems that the problems points to the bearing in the motor.
Posted on May 15, 2010
Starting the dishwashing cycle, extreme loud noise when dishwasher starts pumping water. Loud noise stays during pumping cycle. Dishes are clean and dry and no water in tub when cycle finishes.
If your unit is a Kenmore or Whirlpool (there are several other brands that use many of the same parts) and is less than 6 years old then it may pay to first check and clean out the chopper assembly for hard debris. If that doesn't do it then you may want to consider replacing the motor and circulation pump as a complete unit for between $160 and $200. Not too difficult a task for a moderately handy guy with some tools. Maybe 2 hrs. The bearing itself is not serviceable I understand, and would be considerably more difficult. Over six years old then you can buy a great quality machine for about $500.
Oct 23, 2013 | Kenmore Dishwashers
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
My dishwasher is just three years old. The other night my wife said it made a loud noise while it was running and now it is full of water at the end of the cycle. Any ideas?
The pump attached to the end of the motor shaft inside the tub may have broken. If it doesn't spin the water wont pump out but usually the water wont spray on the dishes either. Watch it run a second with the door open and the door switch make to see if it's spraying.
Mar 22, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher is 1.5 years old and makes loud noise and does not get dishes clean
HI. the wash impeller is damaged. this will cause much noise during the wash and it will affect the nature of the wash dramatically. this impeller is attached to the circulation motor under the sump. it should be replaced asap, if possible.
Aug 01, 2009 | Dishwashers
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
My Energy Star/Built-in
Me to....My dishwasher is about 7 months old. It use to be extremely quiet. Now it is LOUD. but still works fine. HELP!
Oct 18, 2007 | KitchenAid 24 in. KUDI01ILBS Stainless...
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
242 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
