Checking power consumption
How can I check the power consumption on a 26" LCD that I have converted to a monitor. I have a multimeter but don't know where to where to touch the leads to ck for it's power usage in watts.
    Scholar:
  • 35 Answers
To find power usage the safest method is to buy a plug in watt meter or refer to the user manual or nameplate for the power consumption. I would not recommend using a generic multimeter to check watts. but if you want to check it you need to split the wires and put an amp clamp on the hot wire to check the amperage then use this formula to convert to watts in the US:
When Volts and Amperes are Known
POWER (WATTS) = VOLTS x AMPERES
  • We have a small server with a nameplate shows 2.5 amps. Given a normal 120 Volt, 60 hz power source and the ampere reading from equipment, make the following calculation:
POWER (WATTS) = 120 * 2.5 ANSWER: 300 WATTS
Posted on Mar 29, 2008
  • 99 Answers
You need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
Tip
Power Consumption by CRT monitors
<span>Frequent PC users especially desktop PC's with CRT monitors has to be very careful in using the CRT monitors as that consumes more power than other types of monitors in market.</SPAN><br> <span>Recent research has found the CRT monitors to be consuming 60-80 watts of power for a normal 15 inch monitor compared to 25-35 watts for LCD. The power consumption is almost double in CRT's. If you consider 17-19 inch monitor the power consumption in CRT's might go up to 100-150 watts roughly.</SPAN><br> <span>It is advisable for more than 1 CRT monitor users to keep the monitors switched off when not in use so the power consumption is reduced.</SPAN><br>
on Dec 12, 2010 | Computers & Internet
POWER SUPPLY
check your cables especially to the power supply or check your outlet if it is giving the complete consumption of power to the monitor.
Sep 16, 2011 | Mag Innovision InnoVision LT 765S 17" Flat...
No power in monitor
First check for a LED indicator? if there is one is it changing when you turn on your monitor? if there is changing light then the problem might be on the power supply or maybe on the LCD lamp. To check the power supply check for a defective fuse a defective fuse has no reading on multimeter and the o.k has 000 reading. the LCD lamp power supply can be converted into different power supply. hope this may help you.
Jul 27, 2011 | LG Flatron L1750S 17" LCD Monitor
Hannspree 20" Monitor HF205 - What is its' power
Max Resolution 1600 x 900 • 15000:1 Image Contrast Ratio • 5 ms Response Time • 34 Watt Power Consumption
techbelkin
Dec 13, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
VGA cable wire not working
At any computer retailer shop you can get it.just say give the lcd vga signal cable . you will recieve male to male cable you have to convert it by checking continuty by multimeter
Mar 29, 2010 | SAMTRON 55V 15" CRT Monitor
I dont know about capacitors or regulators i just need to know how to turn this thing on.
on the specs from ebay I see you need a 12v dc 5 amp ac power adapter .
normally they have an led , but if you can't get power you will have to verify that you have the 12v at the tip, you will need a multimeter or 12v bulb connected to the end.
if your getting power then the panels circuit is at fault.
talk to a local geek about checking it out.
Mar 28, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Power cord
You can get one at any electronics store. They are quite standard.
Feb 18, 2008 | Mintek DTV-263 26 in. LCD Television
Power consumption/in watts
Most likely 350 or there abouts.
I tried to look up the specs but VGN -NR17G is not a known model number.
Jan 28, 2008 | Toshiba Satellite M35X-S111 Notebook
My monitor has no power on
First thing to check is the power supply cord that plugs into the monitor. Sometimes the internal transformers fail. Let me know if you have power to that. The way to check it is to plug the cord into the wall socket and use a multimeter tester set to DC Volts and see if you get voltage to it. Let me know if you get voltage there
Dec 05, 2007 | Dell E173FP 17" LCD Monitor
Televison & Video Logo
459 people viewed this question
Top Televison & Video Experts
