Question about Acer H243Hbmid 24" Full HD LCD Monitor
What if the words appear blurry on my new monitor
  • 242 Answers
It means that you need to change the display settings. Use the maximum resolution for it.
Right click on ur desktop --> Properties --> select the Setting TAB.
select the highest colour quality that you have and increse the pixels resolution.
Thats all.
Posted on May 12, 2010
WHY won't it TURN ON?
If this is an old monitor then it could be shot. The other thing to check before you throw it out is to make sure all of you cables and connections are good. Substitute the cables for "new" ones and make sure that is not the problem. If your computer is old it could be the video card as well.
Aug 22, 2014 | Computers & Internet
Blurry screen
make sure the monitor is connected tightly from the power source and also from the CPU to its device.. And if it still blurry wherein vertical lines appearing, kindly contact your pc provider for possible repair..
Sep 12, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
The words on the screen are blurry
if you are using windows vista/7, right click, go to personalize, display, change display settings, resolution - try the different settings there to find out which one fits better your monitor. Hope it helps
Feb 05, 2011 | LG L1520B 15" LCD Monitor
My monitor on my HP w2007 turned blurry 2 weeks ago. I ran ZoomBrowser as an administrator to open it. Not sure if I caused the problem or not. As icons and picture on desktop blurry as well as any word...
Check that the data cable of the monitor is properly connected to the back of the monitor and the desktop computer.
If it is properly connected, then most likely a component within your monitor has failed and will have to be replaced. If you have another monitor that you can connect to the computer to compare, you can confirm that the problem is indeed with the monitor and not with the computer itself.
Dec 30, 2010 | HP W2007 LCD Monitor
Image on Monitor is slightly blurry
Try reducing the screen resolution to 1/2 of what it is now!
Jan 20, 2010 | Acer AL1916W 19" LCD Monitor
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Oct 01, 2008 | Computers & Internet
Dell UltraScan P1110 flat-screen monitor BLURRY?
The button you pressed is the reset button and according to the documentaton "returns the monitor to factory defaults".
Here's a link to the Dell support page for your monitor:
http://support.dell.com/support/edocs/monitors/p1110/En/index.htm
Regarding the lines that were orginally were trying to fix; see Damper Wires in Troubleshooting in the above documentation and you'll see that they're a fact of life with this type of monitor. I realize this may not have been your problem, but then again...
I'm surprised that the factory reset made things blurry. Usually this is the result of less than optimum settings on the display adapter in your computer rather than the monitor itself. The Trouble Shooting guide says the brightness and contrast being set too high can cause this so that may be worth checking.
I think you should check your display adapter settings after you try the Troubleshooting suggestions. On the desktop of your computer right click in an empty spot and select Properties. Click on the Settings tab and see what the resolution is. If it's not 1280x1024 you might want to try that. Everything on the screen may suddenly appear smaller so don't be surprised. I would also check the monitor frequency. This will probably be found under Advanced. Every display adapter is different so I can't tell you exactly where to look, just polk around. If you start changing things you may want to write down the original settings so you can at least get back to where you started if there's a problem.
Lastly, I want you to know I'm not paid to provide these suggestions. I know it's a strange hobby, but I like helping when I can. If you find this helpful I hope you'll take a moment and provide a positive rating. About half of the solutions I've posted have never been rated... Thanks and good luck.
Jan 02, 2008 | Computers & Internet
Acer H243Hbmid 24" Full HD LCD Monitor Logo
357 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
