posted by chainmail on Mar 29, 2008
im noob with comps but ive put v266b mother board in tower all wires done but these ones, i know where they go but not right order,as when i switch on no power what so ever,also extra bits for ram can i use them?
Comment by chainmail, posted on Mar 29, 2008
hi,all i can find is this,comp hypermark 0002708 1214, jet.v266b.mboard,rev:3.0
Clarification Request
by Compurepair, posted on Mar 29, 2008
Hi Could you provide details:-
Motherboard Manufacturer:- Gigabyte/Asus et,c.
And model number usually located on Motherboard between PCI slots, or on Mainboard itself.
We can then help you resolve your problem.
Many thanks Mike@ compurepair.
Best Solution
See on board care fully there you found Panel Connector:
Read carefully:
PWS: Means Power Switch. Hoock the power switch from board to this pin. This might be broken, means in distict wire one +ve and another -ve.
PLED: Power Led, connect your power led wire to this, these two wires will be together.
HLED or HDLD: It is HDD led this wire from cabinet also comes together.
RSW or RSET Its reset switch it also comes together from cabinet.
SPKR: This is for internal speaker you can connect the small speaker comes with cabinet. This will be more wider as 1 pin is open in this connection.
Try out this and tell me whether you fixed or not.
Fore more questions, just Ask Me.
Thanks
Iqbal
Read carefully:
Thanks
Iqbal
Rating Locked! (?) chainmail has rated this solution as FixYa!
Solution #2
It appears your board is made by Jetway.
Heres your link for the manual:-
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
You can also download drivers et,c. from the same site.
Please don,t forget to rate the Post.
Best wishes mike @Compurepair
This Problem Also Relates To:
AOpen (MX4SGI4DN2PRE) Motherboard
ASUS (P4BP-MX) Motherboard
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
ASUS Intel 440BX Chipset P2B-VM Motherboard
ASUS P5B-E Motherboard
ASUS P5VD2-MX SE Motherboard
ASUS P5S800-VM Motherboard
Can you Help with these Motherboards problems?
Biostar M6VCG Motherboard
I have problems to see videoes
hola, me knowledge |gustaria|... Answer This...
PC Chips PCChips A13G+ v3.0 Motherboard -...
no video
no video
pc chip a13g+ v3.0 no video is... Answer This...
Repair Service
Find Motherboard Repairman Near You:
