Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Starts runs 10 sec. then dies - Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. If still no help, remove the carburetor, clean it inside and out with spray carburetor cleaner. Check the diaphragm in the lower chamber for flexibility, no cracks or holes. Make sure the components behind the carburetor are in good condition and no plugging of the impulse passage that comes from the crankcase out to the carburetor base. Hope that some of this helps!
Posted on Jul 24, 2010
04 chv p-up 4.8 5sp start an run 10 to 15 min then dies might start 1 more time for 30 sec an die again then start again an gages r trip in an radio
The very 1st thing you need to have done is a scan of the control module for fault codes. You will need a OBD2 code reader for this test, cost about $40 US
May 21, 2016 | Chevrolet Cars & Trucks
Husqvarna 125l carb problems
Check the fuel lines. Ethanol in the gas swells the old type fuel lines.
Jul 17, 2014 | Garden
Just turns off on it's own, Wait 60 sec. restart press pedel it dies.
This engine is electronically controlled so the first thing that must be done here is to have the systems control computer tested for fault codes and then do the proper diagnostics based on those codes.
Jun 07, 2012 | 1995 Plymouth Voyager
1641 cub cadet how to check fuel shut off solenoid
it wont start at all if the solenoid is unplugged try and see if it will run with the choke about half way on if so you have trash in your carb
Apr 21, 2012 | Cub Cadet Garden
Car starts and runs for about 10 seconds then dies but can start rightback up and do same thing run for 10 sec and then die
CHECK FUEL FILTER AND FUEL PRESSURE.......PUT SOME GAS IN THE TANK SOME TIMES GAUGE READS WRONG.......
Dec 20, 2010 | 2001 Nissan Maxima
2500hd dies then starts and dies again
CHECK AIR FILTER FOR RESTRICTION. A BAD SUPPLY PUMP. OUT OF FUEL. BLOCKED FUEL RETURN LINE. AIR LEAK IN SUCTION LINE. RESTRICTED FUEL FILTER. INOPERATIVE FAST IDLE. LOW IDLE SPEED AND DEFECTIVE INJECTION PUMP.THIS IS A LIST OF THINGS TO CHECK.
Jul 25, 2009 | 2002 Chevrolet Silverado
Replace the fuel pump, car start idle fasts for 10 sec. then die
did you replace the line filter,it may be cloged.
Jun 19, 2009 | 1999 Saturn SL
92 gmc c2500 turbo diesel. starts then dies after a few seconds.
Sounds like the Pump Mounted Injection Module.. Starts, dies, Starts dies... Not a fun fix.. but atleast it's just under the intake..
Mar 30, 2009 | 1994 GMC Sierra
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
108 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
