Question about Magic Chef CYE4000AWW Electric Dryer
Not enough gas releasing so will go out - Magic Chef CYE4000AWW Electric Dryer
  • Magic Chef Master
  • 43,501 Answers
Hi, If you have a gas dryernot enough gas releasing - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...not enough gas releasing - 2_bing.gif/>Dryer2_bing.gif Troubleshooting Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 13, 2010
We have Brazilian f5 that ignites the flame but when we release the knob it goes out
Either the thermocouple has failed or it is not heated up enough to keep gas flow going when you release the button. Also could be contaminated fuel. try holding the button for about ten seconds longer, If it still goes out when released, Either the fuel isn't burning hot enough or the thermocoulpe is failing.
Feb 14, 2015 | Heating & Cooling
GE Range oven don't work. Igniter comes on, no gas is released
I recently had a problem with my gas oven, where I could see the igniter glowing but the gas was not coming on, just like your problem. I found out that the igniter needs to draw a certain level of current to allow the gas valve to open. Although I could see mine glowing, it had broken down enough over time to where the current draw was no longer enough. And the igniter is the "weakest link" in the system.
Replace the igniter. It worked for me!
Jul 29, 2012 | GE Kitchen Ranges
Samsung Refregirator RS267LABP is 4 years old. Shows -4 on Freezer and 38 on Fridge but not cooling. All items inside are getting spoiled
38 on Fridge is not enough to cool refrigerator. Please check there is fan, (working ) to spread the cooling to refrigerator compartment. Switch off and restart, if any chock in system could release the gas circulation. If problem still, release gas and flush out system, vacuum and do gas charging. Thanks.
Jan 26, 2011 | Refrigerators
Boot will not lift properly
the boot is released by the gas lift shocks,when they go back then the boot wont clear the lever far enough to release it.I would have the gas boot lift shocks replaced.
Jan 04, 2011 | 2006 Jaguar XJ8
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Gas cap door will not open when release latch is
You might try having a friend bump the gas cover with the heel of their hand while you **** briskly on the release. Have done this a couple of times and once opened, you can use a little lubricant on the exposed parts. Sometimes that is enough.
Jan 09, 2010 | 1994 Honda Accord
Pilot low when release button, goes out after turn on
Try replacing the pilot generator which is in the pilot assembly. It is the piece with a silver cable coming out of it and that cable splits open into a red and white wire at the gas valve, That piece holds the valve open once it is hot enough and is likely not putting out enough voltage to do its job.
Jun 14, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Need to know ohm reading
When room temp, you'll see about 80 ohms. As it heats the resistance goes up, and thus the amperage draw goes up, which is the critical component to release of gas and thus ignition. The ignitor needs to reach 3.2 to 3.6 amps before the gas safety valve will open and release the gas for ignition. Old ignitors get weak and even if they still glow they may not draw enough amperage to allow the oven to work. Also, low voltage will result in lower amperage draw and possible ignition problems.
Nov 28, 2008 | Viking VGSC306-4B Gas Kitchen Range
Magic Chef CYE4000AWW Electric Dryer Logo
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Charles T Nevin
Charles T Nevin
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
