Question about Ovens
Whirlpool oven controls not working, oven will not come on, it does have power. Just keypad not lighting up and won't run oven.
    Scholar:
  • 157 Answers
Research on line the model number for a service manual. The control PC bd or key bd is the problem.
(PC-printed circuit, bd-board). Best Wishes
Posted on May 12, 2010
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Replaced control board and keypad but oven buttons still not working
I pulled the schematic there is a thermal fuse on the neutral wire going to the control you should have 120VAC at terminals P4-3 and P4-1 if not find the fuse back trace from P4-1
Feb 12, 2014 | Whirlpool Ovens
My whirlpool oven locke with F5 E1 what to do
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks
Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
E6 F2 - Works sometimes, then will go out. Light will always work but clock and ovens will not. Whirlpool double oven= I don't know where to find what model it is.
Hi, to fix this error code follow the instruction below...
  • Check keypad connector for firm connection (keypad connects to control board).
  • Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 06, 2010 | Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
I have a Whirlpool RBD275PDS14 double oven. It
Look for a blown fuse mounted on back of the controleb59c28.pngtis page is in the MANUAL
Feb 10, 2010 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 | Ovens
Ovens Logo
123 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
