Question about GE DSXH47GGWW Dryer
GE Dryer model DSXH47 keeps shutting off after about 30 seconds
GE Dryer model DSXH47 I have the above mentioned dryer, it is about 2-2.5 years old (of course, it's out of the warranty period). It has been beeping a code lately, and I believe it is code 6. I took the dryer apart and got the repair technician diagnostic sheet out of it. That code says it is a button stuck. I enter into the test mode and the dryer will spin, get hot, and work just like it should. I do the button test and the dryness selector button doesn't work. I have had the control panel apart and the button seems to work fine. I tested all the buttons with a multimeter and they all read about the same and the reading changes when I press them. I am about ready to destroy this stupid dryer. I feel it should in no way have any problems after this short of a time. The dryer is not overused as it is just my wife and I, no kids. Our laundry amount is minimal.
Paint of dryer inside peeling off
yes request to the landlord to replace it
Mar 15, 2014 | GE Dryers
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
My dryer wont start at all...
Did you check the door switch. If it is open (not making contact) the machine will not run. Could be the motor start/run switch which could be stuck with lint (clean it) or worn out ( replace the motor).
Sep 18, 2009 | GE DSXH47GGWW Dryer
GE Dryer shuts off w/ blinking and beeping
I just fixed that problem with mine. I tried many, many things. Final solution was vacumming out the holes in the rear of the drier. (Prior to that, I removed the lint filter and holder, checked all connections and vacummed out that area. I unplugged the vent hose to confirm there was no cluggs. I found resetting the breaker would work for about a half hour.) Just vacum out the rear of the dry. Not only will the beeping stop, but as an added bonus, you cloths will dry much faster!!!
Sep 01, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Dryer model DSXH47 keeps shutting off after about 30-40 sec.
It could be the door switch. If it vibrates a bit then the door switch senses it's open and shuts down. Give it a look
Jul 07, 2009 | GE DSXH47GGWW Dryer
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
Ge dryer shuts off
turn the drum by hand see if it turns fairly easy if it does then you may need to replace or clean the drive motor if not may need to service the tub rear bearing tub glides etc
Dec 30, 2007 | GE DBSR453EBWW Electric Dryer
GE dryer shut off prematurely and now won't start
I'm having the same problem with my GE dryer. I think that it may the safety thermostat receaching maximum temperature and shutting the dryer down.
I'm currently researching this problem now.
Dec 05, 2007 | Zanussi TC7102W Electric Dryer
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE DSXH47GGWW Dryer Logo
200 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
