Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
How you open a maytag ensignia washer - Maytag Ensignia 3.3 cu. ft. Top Load Washer
  • Maytag Master
  • 8,220 Answers
The older models had screws at the base to remove. The newest ones have spring clips instead of screwshow you open a maytag ensignia washer - 1c7ff10.jpgthis is a dryer but basically you washer fron panel comes off like this when you release the spring clips on each side with a simple putty knife.
Posted on May 12, 2010
5 Suggested Answers
  • 410 Answers
SOURCE: ensignia washer sicking in cycles
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 30, 2009
  • 767 Answers
SOURCE: Washer does not spin and I think the belt is
If the back doesn't come off the you will have to lay it dowm on the front to get to the belt throught the bottom.
Posted on Mar 07, 2010
SOURCE: Maytag Ensignia Washer Leaks
I have the same problem. Just took mine apart here is where you can see how to get the front panel off. If I figure out the problem I'll post an update.
Panel opening:
http://www.applianceaid.com/atlantis.html
Posted on Feb 28, 2008
  • 2468 Answers
SOURCE: my maytag ensignia washer vibrates/shakes as it
you need to level the unit and then lock the jamb-nuts between the leveling legs and the bottom of the units base structure,use a level and check the top,then level the unit as best as possible,per the floor grade,then tighten the jamb nuts to keep them there
Posted on Jul 05, 2010
I have a Maytag Ensignia washer that will fill with water and start working but will not advance to the next cycle without manually advancing the dial. once helped into the next cycle the washer works...
First you need to list the model number in order for me to figure out what type of washer it is then i can help you. The reason I ask is some Maytag Ensignia's come with electronic timers and some models have old style timers...
Mar 10, 2013 | Washing Machines
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
I have a Maytag Ensignia and the water will run but the tub will not fill.
You may have to just raise the drain hose up higher. It sounds as if the water is going out the drain hose as it tries to fill.Drain hose should be up as high as the top of the washer.Hope this helps.
May 28, 2011 | Maytag Ensignia MAV2757AWW Top Load Washer
My maytag ensignia washer vibrates/shakes as it rinses
Jul 05, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
My Maytag Ensignia washer is making a clunking noise like something is loose when it is in the rinse cycle.. also does not appear to be spinning as well as it should. What could be wrong with it
Mine had the same problem! Turned out to be the transmision going bad. My machine is only three years old. Transmision cost over $250 Not worth fixing. The inside of this machine is very poor quality. I am very disapointed. Maytag not the quality it once was. I WILL NEVER WASTE MY MONEY ON A MAYTAG PRODUCT AGAIN
May 24, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer does not spin and I think the belt is broken, How do I open it to find out. It is a Maytag Ensignia washer.
Mar 07, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
1,457 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
