Question about Fargo DTC525 ID Card Printer
After printing the ID, It gets stuck inside the printer. I need to lift the print head and manuallly push the ID out.
  • 493 Answers
Hope the picture helps to lift the print head.
Best wishes.
Posted on May 12, 2010
How to change the pin head
I assume your asking how to change the "Print head" power off the machine, remove the ribbion and plastic mask (lifts up) you will see 2 gold phillips head screws. unscrew them both and lift up the print head. push in new print head and reverse the directions you removed.
Jul 24, 2014 | OKI MICROLINE 5521 Matrix Printer
Tip
How to reseat the print head on Dell Photo P703w All-In-One Printer 1....
1. Disconnect the AC power from the printer
2. Lift up on the print head from the lower left corner
3. Gently pull the ribbon cable to move the carrier to the center
Note if the carrier is stuck under the lid and will not move with gentle pressure, then you may need to plug the printer back in before gently pulling the cable.
You should now be able to see the carrier at the top opening of the printer
4. Next remove the ink cartridges
5. Now press down on the center of the print head. You will want to press firmly until you hear an audible click sound.
6. Next test the assembly by trying to lift up on the printhead. If it lifts up, repeat step 5.
If the printhead does not lift up try pushing the carrier to the right.
7. Close the top lid and plug back in AC power
8. Turn the printer on and check to see if the paper jam error is gone.
on Sep 10, 2010 | Dell P703w Printer
How to install ink catridge
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Check for any instructions on the inside of the lid.
After a few seconds, the ink-cartridges will slide to a new position.
Unlock the cartridge from its socket, either by moving the lever,
or by pushing-down on the cartridge, and gently lift it out.
Insert the new cartridge. Lock it into the socket.
Run a "print-head" alignment cycle, for optimal colour-printing.
Oct 22, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How do i get the ink cartridge out?
Lift the lid.
Look inside the lid -- some printers have "instructions" printed there.
Or, just wait 10 seconds, and the print-head will slide into position.
Push down on the ink-cartridge to "unlock" it from its socket.
Gently remove the ink-cartridge.
Oct 19, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Advice me how to replace cartridge on 2410 printer Thanks
Lift the cover over the print-head mechanism.
Look for instructions on the inside of the lid.
After a few seconds, the print-head will slide to a position from where the ink-cartridges can be slightly pushed DOWN, to "unlock" them from their socket, and can gently be lifted out.
Sep 27, 2010 | HP PSC 2410 All-In-One InkJet Printer
Where or how do I open my lexmark 7500 to replace ink
Check for printed instructions inside the lid. :-)
Or, wait a few seconds, and the print-heads will slide to a position where you can remove the ink-cartridges, either by lifting a locking-lever, or by pushing-down on the ink-cartridge to "unlock" it from its "mounted' position. Then, slide/lift out the ink-cartridge.
Sep 20, 2010 | Lexmark X2650 All-In-One InkJet Printer
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printing error
the problem is with the printer. try to examine if the printer head is on the right side. the default must be on the right side. if you can't move the printer head towards the right it means it got stuck up. if you will look inside it you will see a 'rail like' object on the bottom of the printer you can push it down with any pointed object for the pinter head to get back to its original position. if this doesn't solve the problem look for the nearest service center coz the printer needs an alignment.
Aug 10, 2008 | Casio HR-8TMPlus Calculator
Canon MP830 print head
If you purchased the printer new, you would have had to install the print head before youput the cartridges in. The print head id he bit the cartridges clip into. So to remove the print head:
Open the cover, take out all five print cartridges and then lift the lever on the left of the print head and remove print head.
Hope this helps!
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
ERROR 41 ON BROTHER mfc 3820CN - PRINT HEAD
This is definitely the print head. You will need to purchase a new print head and install this. It is very easy to install all that you need to do is lift the printer lid and extract the ink cartridges. The printhead is the black part under the ink cartridges and on either side of it is a lock and release bar. push these down and out wards to loosen them and then lift the print head out. replace the print head and then you will need to input the print head ID in maintenance mode on the printer. Turn the printer off and hold down the menu/set button and power on. You will here it beep and all the lights flash on the panel. The punch in 68 2580 I think from memory i could be wrong but just look it up if you can get hold of a service many and then enter the new printhead code and 99 to exit. Done Hope this answers your question.
Jul 03, 2008 | Office Equipment & Supplies
Fargo DTC525 ID Card Printer Logo
151 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
