Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Pump won't chlorinate - Intex Automatic Salt Water System for Above Ground Saltwater Pool
This could be due to a number of different things. Will need more info from you. Did you put the recommended amount of salt for the pool size? Did you allow 24 hours and brush the pool bottom in order for the salt to dissolve on the initial setup? The Element that creates the chemical reaction may not be working at capacity or at all. The element and copper electrode will need cleaned monthly. See your owners manual under maintenance on how to clean those items. The easiest way to know if the element is working is you should see bubbles in the tube. It is a gas created by the chemical reaction, which is normal. Also, you may simply be losing generated chlorine in direct sunlight. If you have not done so already, you will need to add stabilizer. Hope this helps.
Posted on May 18, 2010
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
Water in pool seems cloudy now
If it seems clowdy now it is probably low on chlorine and unless this is corrected it will turn green in within a day or two. My suggestion is that you bring a sample of your water to a pool supply store and they will test it. If you have filled the pool recently with new water the two things you should be most concerned about are chlorine, stabilizer ph and alkalinity. Since your pool is clowdy the chlorine should be about 10 ppm and the stabilizer should be between 30 and 50 ppm. If you are short on stabilizer the chlorine will be gone very soon. If you have too much stabilizer the chlorine will say in the pool but it won't be as effective. Since the water is new the ph and alkalinity should be ok but the source of your water might be poor. Alkalinity is based on the amount of sodium bicarbonate (baking soda) in the water. If the level is right it helps keep the ph stable. Most municipalities supply water with 80 ppm of sodium bicarbonate in order to maintain their ph more easily. If the ph is too high it is base and causes the chlorine to be not as effective and it causes other problems when it is too low. Adding acid to the pool reduces the ph and adding sodium carbonate or sodium bicarbonate increases the ph. Since the water is new I would automatically shock the pool to 10 ppm of chlorine and treat with stabilizer to 30 ppm and then see how it goes. I wouldn't let anyone swim until the chlorine drops to between 2 and 4 ppm, the pool bottom is clearly visible and no dirt, etc is visible. I hope this helps.
Aug 13, 2011 | Intex Krystal Clear Model 635 Pool Filter...
My pool is cloudy and I added clarifier and it still won't clear. I checked the salt count and it's reading 1100 ppm. We have a 15 foot round 48 inch deep pool. I also shock the pool weekly...
1st... Your salt count should be at 3000 ppm... For your size pool, the start-up salt needed should be about 95 to 110 lbs..
2nd... Run your pump for 24 hrs without the chlorinator after you have reached the 3000 ppm to properly disolve the salt and use only "pool salt"
3rd... Set your pump at 12 hrs and your chlorinator at 10 to 11 of those hrs until you have reached the desired chlorine level.
4th.. After your pool water has cleared, within 2 to 3 days...clean your chlorinator electrolytic cell and adjust your time down to maintain the proper chlorine level..
Hope this helps and if it does, please rate and comment....
Good Luck!!!
Jul 31, 2011 | Intex Automatic Salt Water System for ...
Can't keep water chlorinated
Chlorine evaporates rapidly in an open pool. Cover it when not using it and the chlorine will last much longer. J.
Jul 03, 2010 | Intex 12' 36" Easy Set Pool Simple + Pump...
Is a Hayward cl-100 ef chlorinator the right model to use for a 27 foot round above-ground swimming pool. I am having trouble keeping the chlorine level at an adequate level (dips too low) even with the...
The cl100 should do the job. The first thing I would do is check the chemicals. Make sure you have enough stabilizer (cyanuric acid).If it's low your chlorine will not last long at all. Check the ph and alkalinity also. Make sure you are running the pump long enough. the cl100 only adds chlorine when it's running.
Jun 05, 2010 | Hayward Pool Products 25 Sq Ft Micro Clear...
How can i determine if my water chlorinator on my well water conditioning system is functioning properly ?
I expect this is a tablet style chorinator, if so look to see if the chlorinator is using chlorine tablets. These chloriantors work off a run time clock tied to the well pump; when the well pump runs the timer within the chlorinator is energized, after a predetermined amount of "run time" the chlorinator drops a tablet. If you feel it is not operating properly I'd bring in a water well professional; remember we are speaking of the aquifer, too much chlorine in your water may affect your neigborhood.
I hope this may have helped,
Tom
Oct 04, 2009 | Plumbing
Cleaning the inside -Pentair 320 Chlorinator Model R172276
their is a set screw in the side of the chlorinator towards the bottom (you should see a little hole in the side of the chlorinator near the base). remove that screw and the chlorinator will unscrew from the base.
Jul 13, 2009 | Pentair 2.0 Hp Whisperflo Pump
I have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Jul 12, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
387 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
