Question about Kenmore Elite HE3 Steam 8674 Dryer
The drum is drum is very loose (don't know if this is normal)
It clunks.
  • joeannhub65 May 13, 2010
    I've found the problem. Ironically someone had the exact same problem. A zipper foot had gotten stuck between the drum and the felt and unbalanced the drum causing the clunking. Found the zipper took it out and no more noise.
    Scholar:
  • 157 Answers
Hello, First disconnect the AC power, and if unit is gas close the gas valve. Next research on line for service manual or open the housing to visual check the drum rollers and their support. If bad the manual or local parts supply should ID the parts and cost. Best wishes.
Posted on May 12, 2010
Have a 2004 polaris ATP 500 when turning there's a clunking noise I changed wheel bearings and noise still there ! Checked u joints not really a lot of play in them!
2011 Sportsman 500 Trans Clunk - ATVConnection.com ATV Enthusiast ...
atvconnection.com/.../polaris/343211-2011-sportsman-500-trans-clunk.h...
Mar 21, 2012 - It is really noticeable when wheel is turned when you get on the gas from a. ... 2011 Sportsman 500 Trans Clunk ... You have to figure from the motor to the clutches,then to the transmission,then to the drive shafts,there is going ... 1999 Sportsman 500,slight clunk from dead stop
Feb 28, 2015
Clunk or pop in the steering on an 07 Sportsman 500 ...
Aug 8, 2008
500 HO, rear end noise
Apr 29, 2006
clunking noise on scrambler 500...
Jan 31, 2000
More results from atvconnection.com
Sep 25, 2015 | Cars & Trucks
Clunk when breaking
Can be several things. Often a sticking brake caliper or worn brake pads can clunk. Sometimes the transmission can clunk when the Torque converter unlocks. A bad U-joint can clunk when the brakes start slowing the rotation of the differential.
Someone needs to check the brakes and driveline.
Feb 24, 2014 | 2001 Lincoln Navigator
Clunk on acell on throttle tip in from 20 mph
I understand what your saying
I don't know what clunks
Is the clunk on a trans shift,like a drive axle CV joint?
Mar 14, 2013 | Cars & Trucks
1999 chevy lumina clunking noise in rear
Hi Ryan, If you were here in Africa I would say its probably shock absorbers. If your roads are anything like ours, check those and the exhaust system hangers for anything that may be broken. Regards John
Aug 06, 2012 | 1999 Chevrolet Lumina
Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Nov 18, 2011 | Hotpoint Refrigerators
Will clunk hard when accelerating slowly, and then
Is the clunk noticed as soon as the brake pedal is released? Your brake shoes engage in the rear drum when the brake pedal is pressed and then release as the brake pedal is released. Your shoes may be worn and might be "hanging up" for a brief period, that would make a clunk sound your describing
Feb 16, 2010 | 2004 Chevrolet Silverado
Power windows won't work. they are not rolling up or down.
It can only be one of a few things. First if it is the switch it won't make any sound at all when you press the button. If you can hear a sound, then the motor is running. If it has a 'clunk-clunk-clunk' sound to it then the gear plugs in the window motor need replacing which always happens around 10 years old. If you hear the motor running without the 'clunk-clunk-clunk' then the regulator cable has jumped track and the regulator will need replacing.
Nov 13, 2009 | 1996 Cadillac DeVille
The cassette or hub "clunks" on my mountain bike
it sounds like the barrings your going to have to bring it to a shop or buy a new wheel
May 03, 2009 | Sram 850 8 Speed Cassette 11-32t Mountain...
04 Sportster 883 gearbox Clunk.
Big Twins clunk too, especially into 1st with a cold motor, even if you free the clutch off first. When I remember, I snick it into gear, pull in the clutch and roll it back and forward to free off the plates. And it still clunks. Sometimes, you will slip from neutral into 1st, almost with no effort, and no clunk and so smooth you don't believe it's engaged (but it is). Weird. I have smooth changes from 4th to 5th and back again, sometimes from 3rd to 4th, but 3rd to second and second to 1st are always a BIG clunk, even if you give it some stick to try and match the revs before changing down. I now go from second to neutral and then into 1st, which is not a lot of fun when you are negotiating a hairpin on Glenquaich at the time... A tighter primary chain seems to reduce the clunk, and there are those who say that auto primary adjusters/tensioners (does a Sporty have one of them?) reduce the clunk. Some disagree... Assume you find it's much better when it's hot..
Nov 20, 2008 | 2007 Harley Davidson XL 883 Sportster
Kenmore Elite HE3 Steam 8674 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
