My mp3 player wont turn on, it will when you plug it in
  • danielle_tay May 13, 2010
    its a innovage mp3 player and it will turn on while i have it charging but when i unplug it, it stops working
    President:
  • 2,923 Answers
Once the MP3 player turns on only when connected to the computer, but won't turn on if it's not connected, then you only have two possible cause of the problem.
1. Defective Battery
2. Loose wire connection
If you have a multi tester (analog or digital), you can try to take the battery out, and see if the battery can still hold a charge.
Check also the wires, and I'm sure that one of the wires got cut off.
However, if your player is still under the warranty, contact the manufacturer and have them repair it for you.
Thank you and good luck!
Posted on May 13, 2010
  • 493 Answers
Hİ,
You should change the battery or charge it if it is chargeable. (If it is battery operated.)
Because you say that it works when you plug it in the PC. So it charges from PC, that's why it is working.
Hope this helps.
If not, waiting your comments with the name and model of your MP3 player.
Best wishes.
Posted on May 12, 2010
  • Ibrahim OKTAY
    Ibrahim OKTAY May 13, 2010
    The following information related to the battery charging of your mp3 player helps you to solve your problem.
    1. Power on the unit, connect the unit by USB cable to the charger and plug-in the charger to AC power sources or connect the unit by USB cable to your PC/Notebook.
    2. Charging time: Normally, the charging time will be at least 4 hours to fully charge the unit. If charging through PC’s USB port by using USB cable. The charging time will take at least 6 hours
    You must have the power on the player be in ON position while charging the lithium battery. Otherwise unit will not charge.
    - Do not use a charger that is defective.
    When using the rechargeable battery for the first time or several months of non-use, fully charge it first.
    - Overcharging will reduce the battery life.
    - The rechargeable battery is a consumable item and its capacity will decrease gradually.
    - To prolong the life of your battery, use the fully charged battery until it is completely discharged, and then fully charge it again before use. If you charge the battery that is not completely drained, the battery using life cycle will
    decrease.
    Hope this helps.
    ioktay
Hip street hs3245 mp3 player wont charge
my problem is my mp3 wont turn on. it turn on just when i plug my hip-streed on my cumputer, but when i disconnect it it wont turn on...
Jan 12, 2011 | Kobian HS-3245 MP3 Player
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
JWIN mp3 player
try holding the play button for 10 to 20 second it's probably come on.
Jun 29, 2009 | Jwin MP3 Player
Mine wont turn on
On the back of the the mp3 player is a reset switch.
Hold that down about 15 seconds.
If that does not work go to the RCA website.
Download the latest firmware.
Plug mp3 player into pc.
Install the new firmware.
Keep it plug to computer for about 1 hour to charge the battery alittle.
Dec 27, 2008 | RCA M4204 MP3 Player
Nextar MA715 MP3 player wont take a charge.
Best first bet is dead battery. If it is a special battery then do the costings for the repair as it may be cheaper to replace the player.
Jun 13, 2017 | Nextar MA7151B MP3 Player
Turning on my mp3
try going here and downloading the firmware it worked for me
http://support.rcaaudiovideo.com/downloads.aspx?product=192
Nov 16, 2008 | RCA OPAL M4001 MP3 Player
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Computers & Internet Logo
David Payne
David Payne
