Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
I need three missing screws for the back handel holder
Also I would need the owners manuel to operator this unit. How do I go about doing this, Please advise me. The phone for the USO in San Diego is 619-235-6503 and our email address is Sara@usosandiego.org we really need the owners manuel. thank you very much its for the troops.
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: need manuel
Here's the link to the manual; http://www.bissell.com/images/UserGuides/9200-605web.pdf Hope this helps, if not please ask again with a bit more detail of the specific problem :)
Posted on Jun 18, 2007
How do I replace carbon brushes in vax6131
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. Give that a try and let me know how that works for ya.
Jun 11, 2011 | Vacuums
How do i get the lower handle cover off so that i can get to the water heater on my bissell proheat 2x model #9200?
on the back just above the unit there are two holes that are long and skinny and have a screw(phillips).there is also a small screw on the back of where the cord comes out.you must also remove the other screws higher up on the back(these screw into the front plate of the machine) warning,the heater is not in the handle as some have shown online.unscrew any of those that look like they attatch to the front face.there is also one behind the lower hose holder(pull it off and you will see the screw
Nov 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
Basic how to use instructions.
1. Step on the handle releae pedal and lay the handle back.
2. Remove the tank and take it to thesink.
3. Remove the top cover cover and fill the plastic bladder with water only.
4. Replace the tank.
5. Your 'Smart Mix' (shampoo) bottle is on the operator's right in front of the machine. Remove it and fill it with Bissell shampoo.
6. Shampoo is automatically mixed with the water as you dispense it depending on how your 'Smart Mix' Knob is adjusted.
You can download your complete maual here:
http://www.bissell.com/searchresults.aspx?searchtext=1698&mode=userguides
May 20, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Where does the shampoo go
shampoo goes in the tank located on the back of the unit in the base.
Click -->here<-- to download the owners manual.
please take the time to give this solution a fixya rating.
clarkco
Feb 19, 2009 | Bissell 1699 ProHeat Clear View Upright...
The handel broke on the Tank-in-Tank
If your unit is still under MFG warranty they will replace it at no charge. You can take it to a local appliance shop and they can have it replaced for you. I don't believe that Bissell will ship directly to your home without having it looked at by and authorized repair facility.
Dec 08, 2008 | Bissell 8910 ProHeat Clear View Upright...
How to change carbon brushes in Vax 2000
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. This is tricky but can be done.
Aug 31, 2008 | VAX Appliances Vax X5 Bagless Upright...
Need manuel
Jun 18, 2007 | Bissell 9200 Upright Vacuum
Brushes don't spin but it still has suction
The brushes are usually connected to a motor by a rubber belt. These can wear out and snap (particularly if the brushes are clogged with hair). Usually the bottom of the vacuum can be removed by undooing a few screws and gently pulling it downwards. If the bottom doesn't want to come off, hunt around for any screws you may have missed - the designers seem to think it's funny to hide them. Once the bottom is off, check the belt and remove any hair wrapped around the ends of the brush bar. If the belt is broken you will need to find a replacement.
Apr 23, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
