Question about Dometic RM2652 Refrigerator
Suction line froze up - Dometic RM2652 Refrigerator
  • Dometic Master
  • 8,220 Answers
Overcharged
Posted on May 12, 2010
How do i dismantle the aicon unit
First thing u have do is pumpdown the unit close discharge line wait for few seconds check the suction line when coolness of suction line goes also close the suction valve and then dissconect all power supply then u can remove copper tube and easily dismantle a/c unit.
Oct 05, 2014 | Mitsubishi MSZ-A24NA Split System Air...
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
All the coils on the unit outside froze up
Hello, if the inside fan was not running then the evaporator coil cannot absorb enough heat to vaporize the refrigerant, and the suction line will freeze including the compressor. Liquid refrigerat instead of vapor passes thru the suction line into the compressor. Lack of airflow or a low refrigerant charge is what will cause the line to freeze. In your case it was no airflow
Jun 14, 2012 | Goodman Heating & Cooling
Tapped the suction line @ the compressor & the 410
thats a good question? due you mena 410 psi
Jul 25, 2011 | LG Heating & Cooling
My fan isn't running but I can feel cold air leaking out of my vents. Is it frozen or is my fan motor just dead?
If the indoorcoil is froze, the insulated suction line would be froze as well. If you are able to change the
blower speeds Black-High Speed with Blue-Med High
and nothing changes you could have a blower problem
Jun 21, 2010 | Goodman CKL36AR36 Air Conditioner
Superheat Problem
Superheat is the dif. between suction temp on the gauge and temp on the suction line. Make sure you are measuring the right line/ Normal superheat is between 10 to 14 degrees depending on line length. Russ
Aug 15, 2009 | Heating & Cooling
Suction line replacement
we cut a 12" hole.
David
May 23, 2009 | Pool & Spa
Leaves in the skimmer line and its plugged
Is the obstruction on hte suction side or supply side of the pump?
Either way, you can disconnect the pump, and work from there. If the pump was installed correctly there shgould be unions ( fitting that can be reconnected on the pump suction and supply. If not, you can cut the pipes a few inches from the pump and then shorten the remainder to acomodate the length of the union. Glue these in place follow the instructions on the glue can.
Try using a water hose with the water on from the direction of the pump to the pool. see if this does the job. Leaves should be able to be pulled through by the oumop, I suspect somthing larger. Do you have a strainer on the suction line? Have you checked the pool filter?
I would check the filter first. Why do you think the problem is a clogged line? How do you know the pump is performing? Does it run a Spa, and nbot the pool?
\Good Luck
Mar 17, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Dometic RM2652 Refrigerator Logo
66 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
