Question about Iomega (33600) 160 GB USB 2.0 Hard Drive
Iomega lphd160-u beeping
I just bought this external HD and I cannot use it. It just starts beeping when connected and the computer does not detect it
  • 2 more comments
  • Anonymous Nov 03, 2008
    I have exactly the same problem and I can't find a solution!
  • Anonymous Nov 04, 2008
    I have the same problem with eht Iomega MDHD 750 . If you leave it beeping for about five minutes, it kicks into action, but sometimes fails later while you are using it.
  • Anonymous Dec 23, 2008
    I have exactly the same problem and no soution yet.
  • badempsey Mar 08, 2009
    I have an Iomega 160 GB USB 2,0 I keep my iTunes music library on the external drive.  When the drive is not active for a short time the drive starts "beeping" and dissapears from my Macbook (using Leopard OS).
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Posted on Aug 26, 2008
The same thing happens with my moms iomega. Wish I knew the answer!
Posted on Jul 03, 2008
SOURCE:
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
Jan 11, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
I have just purchased a 1tb Iomega Select external HD
please change the boot setting in BIOS to hdd first then other and save it .... now try to connect the external hdd to pc and switch on .......................... ( make sure your internal HDD should be first boot able device .......)
Dec 31, 2009 | Computers & Internet
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
Nov 26, 2009 | Iomega (33654) Limited Edition 500 GB USB...
Weird clicking sounds
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Iomega Minimax HD, no power but lead light is on. Working fine, then I turned it on today & nothing, no fan, no light but the power lead green light comes on. How do I know if its the HD or the power lead...
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
p.d.
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Apr 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega mini max external HD slowing things down
the hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Mar 06, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Portable Hard Drive refuses to stay linked with PC
I'm thinking the usb port being used on the home pc may be bad. Do you have any others available to use?
Jul 06, 2008 | Iomega (32453) External ZIP Drive
Iomega (33600) 160 GB USB 2.0 Hard Drive Logo
8,058 people viewed this question
Top Iomega Computers & Internet Experts
Ekse
Marvin
Marvin
Gustavo Ortiz
Gustavo Ortiz
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
