Question about InFocus LP290 1100 Lumen XGA LCD Projector Multimedia Projector
Color shift I have an older infocus lp730 projector that is suffering from color shift.( The red color is out of alignment) I'm looking for a repair manual, or any tips on how to align the lcd mirrors in it.
  • 563 Answers
Hi there
There is unfortunatelly no section in the Service Manual to explain this sort of procedure.
You'll have to move the LCD panels one by one - millimeter by millimeter.
Posted on Apr 01, 2008
The picture suffers from colour fringing
either the color wheel has lost a segment or the colorwheel index needs to be adjusted in the hidden menu using the color ramps test screen.
Jul 20, 2010 | InFocus ScreenPlay 4805 Multimedia...
I cannot get the color red. a tomato is not red.
replace the colorwheel. you can get the part from an infocus service center and replace it yourself or send it to one for repair. either way, try av solutions in ny. they're really good.
Jan 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
My InFocus Proxima DP6150 has images with red outlines shifted to one side. colors appear to be separated. Is there a way to fix this?
Service Code
The service code to enter the service menu is as follows:
` Press menu, then service, enters the following: Magnify Volume up, Volume down, Power, Menu, Source and enter.
Nov 25, 2009 | InFocus Proxima DP6150 Multimedia...
My InFocus 4805 SP projector is showing just black and white
If you have any video at all and it's only Black and white there is a 99.99% chance that your Color Wheel has lost all of it's glass color filters.
You can confirm this by removing the lamp. then look straight into the projector where the lamp was and you should see the color wheel of colored glass segments (Red, Green and blue) I believe you won't see them because they came off of the wheel.
Also if you lift up the projector and turn it around in various angles and you will hear the small pieces of broken glass from the color wheel.
Unfortunately you will need to take it to an authorized service center for repair. Be prepared to spend upwards of $300 for the repair.
Aug 23, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
Replaced bulb in infocus 777 and background is red not black
Its not the bulb. I have repaired a few of these with color issues. and its caused by short wires that nearly pull out of were there plugged in at. A big fail on the part of the manufacturer.
you have to open it up and check all the wire connectors. Even a plug thats slightly pulled out can cause issues.
Feb 12, 2009 | InFocus ScreenPlay 777 Multimedia...
Color shifting
this common to dlp projectors! THe DLP wheel has a has lost its alignement
the best way to solve this is to gt a new dlp wheel replacement
Feb 08, 2009 | Sharp XR-1S Notevision DLP Projector, 800...
Red color absent from projector picture
try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
882 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
