Question about SanDisk 2GB microSD Memory Card
2GB Micro SD needs format code that I never gave it
I have a SanDisk 2GB micro SD card, took it from my old phone, want to format in my new phone and it's asking or a format user code. I never knew it had one, I never assigned it one, I don't know one. Can you please tell me what I can do? The old phone formatted it to 1GB, but new phone is capable of using 2GB and so I'd like to reformat on new phone not old one. Thanks!!
  • 493 Answers
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Posted on May 12, 2010
Sandisk micro memory chip not working in my lg620g cell phone
The LG620g works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work in this phone. You need to use microSD cards, 2GB and smaller.
Nov 30, 2012 | SanDisk 8gb Micro Sd Memory Card Class4...
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
You can find Micro SD cards here for purchase.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=micro%20sd&IsRelated=1&cm_sp=KeywordRelated-_-micro_sd_card-_-micro%20sd
Sep 22, 2011 | SanDisk 2GB microSD Memory Card
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
My sandisk micro sd card got locked up. even i
nothing new. It happens a lot . sry but ur memory card data will be deleted./. u will have to format it.. that is the only option ..connect it to pc via card reader and format ur card
Aug 14, 2009 | Nokia 5300 Grey Cellular Phone
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Jan 19, 2009 | SanDisk 2GB microSD Memory Card
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
336 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
