Question about Vizio L32 32 in. LCD HDTV
The tv was clicking numerous times before coming on. now it won't come on at all.
  • 87 Answers
Easy power supply fix for a qualified shop. Estimate in range of $125
Posted on May 12, 2010
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Philips 42pfl7403d
Hi tarheel23693,
The symptoms you've described is an indication of fault most commonly on the power supply board. I've encountered it most of the time in our repair shop. Resolution can be DIY depend on your skills in electronics. Email me at jimvincentvillanueva@yahoo.com if you feel you can do it to assist you further.
Have a nice day,
Jdvillanueva
Jul 24, 2013 | Televison & Video
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Sometimes when i go to cut my tv on it clicks like it is comming on and then a few seconds later it clicks again and the red light flashes numerous times.. Have to unplug and replug several times to get...
Possible that there is a solder joint problem in the main board. Since the TV comes on after you try to put the plug in several times, then this is quite possible. Use a good soldering iron to do this touch up job specially on high power components and on the suspected IC joints.
If you put the set On for some hours and then by tapping if the TV comes on then this fault is confirmed. Also please look for faulty capacitors, for capacitors that has leaked or reduced in value- look for bulged capacitor tops.
Please take care to attampt this job and not to tamper.
Hope this advice helps?
Aug 21, 2010 | Televison & Video
Clicking sound in back of tv when you try to turn it on
Sounds like this could be a dry soldering joint in the TV power circuit. This can easily be repaired with a small soldering iron and soldering wire.
Best wishes,
Graemevm
Jun 06, 2009 | Philips 27PT543S 27" TV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
