Question about Miele Dishwashers
We have a Miele dishwasher G785 SC water outlet blocked
Water outlet light is on. The water gets trapped at the bottom of the dishwasher however the two filters in the bottom are clean. we emptied the water and cleaned the basket and filter however we found everything to be clean. yet the water gets trapped again next time we run the dishwasher
  • 54 Answers
SOURCE: Dishwasher element?
dispenser is not linked that will be the solinoid valve on the dispenser. the heater could be open circuit or on the side of the wash motor is a pressure switch that is common for blocking so it will not put the heater on.
Posted on Feb 12, 2008
Master_Tech
  • 770 Answers
SOURCE: Miele Dishwasher G856 SC cleaning assistance
Yes run a cycle with 2 cups of vinegar to flush it out
Posted on Mar 15, 2008
SOURCE: check water light is on
I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
Alan
Posted on Jan 17, 2009
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
  • 122 Answers
SOURCE: outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Posted on Sep 23, 2009
Miele Dishwasher 626 SC starts but no water is received and it stops soon after. Water supply is ok and has pressure. Main solenoid is also ok. Any suggestions?
Is the drain pump working? is it fed to a sink trap and end hasnt been cut out.i know but ive had this happen when sent to check a machine!pump is always first part of program
Apr 17, 2017 | Miele Dishwashers
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Hi, i have a Miele G 693 SC plus which had the red light lid up: evacuation problem or entry of water, how can I solve this problem ? Furthermore I have tried to download a manual to try and find a trouble...
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Aug 14, 2010 | Miele G892SC SS Dishwasher
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Outlet/inlet light flashing on miele dishwasher G674SC
Sep 22, 2009 | Miele Dishwashers
Miele dishwasher won't drain
try removing the pump cover in the sump to see if it is blocked or jammed. it tells you how to in the user manual.
Jul 16, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele Dishwasher G664
Make sure the drain line goes up as high as it can then strap under sink, then let it come down to disposal. This acts like a trap so water roll back into dishwasher.
Dec 16, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher won't fill - inlet/outlet light comkes on
check no water in the base either by taking front bottom panel off or tilting back. if water runs out, means you have a leak. could also be inlet valve open circuit
Apr 10, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
196 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
