Question about Car Audio & Video
Ford 3000 trafic code
M010139
  • colinlilly May 12, 2010
    code for ser.no.above please.
  • Car Audio & ... Master
  • 4,844 Answers
Try code 3893
Posted on May 13, 2010
Testimonial: "NICE ONE,CHEERS."
I need the wiring diagram for a Ford Radio Casete 3000 Trafic 2 Channel Audio system. Serial No MO73836 P/N 97FP-18K876-NA
  • Hi, I have uploaded two different pics below. Notice on the top pic there are not as many tabs as on the bottom pic. This is how you will identify which one you have. It will be one or the other.
  • This is how the radio will look on the backside so if you turn your radio on its face so you see the wiring harness just match up the hole pin out in the picture with the same spot for the wire on your radio and you will have the color code.
  • You will be able to tell which side is the power feed side because the ground wire is solid black and on the power feed side as well as a solid red power feed wire. The other side will be the speakers.
  • Hope this helps.
Regards, Tony
Oct 16, 2011 | Audio Players & Recorders
Winstar 1999 transmission works in revers only after stop at read trafic light
check ur fluid level in trans for correct level, discoloration an burnt smell,these vans are always at tranny shops gettn overhauled, very possible ur unit is gonna need o/h. u should try to get codes pulled on ur vehicle computer system,if trans is cooked ull get codes leading u to conclusion of a bad trans. good luck
May 01, 2011 | Ford Windstar Cars & Trucks
3000 trafic radio car lock 11 serial no-M225196 PART NO-XS6F-18K876-BA i need for unlock code
Your code is 7137
Make sure that you have quoted the correct SERIAL NUMBER (M225196) as you only have 2 more attempts before your radio is fully locked.
The correct Serial Number is the one found on a label on the radio casing as the one quoted in any paperwork may be incorrect
Dec 30, 2010 | Ford Car Audio & Video
Ford 3000 trafic radio code needed after a battery change
The radio will have to be removed from the dashboard.
Then post the SERIAL NUMBER found on a label on the radio casing
May 10, 2010 | Car Audio & Video
Quote the SERIAL NUMBER found on a label on the radio casing
It normally begins with M ++++++
Mar 17, 2010 | Car Audio & Video
Escort cuts out some times when i pull up to trafic lights doggy revs i have changed the idle valve
run scanner for trouble codes, some auto parts stores will do this for free, check timing belt
Oct 04, 2009 | 1997 Ford Escort
Ford radio 3000 traffic code
Post the SERIAL NUMBER found on a label on the radio casing.
It normally begins with M * * * * * *
Aug 30, 2009 | Car Audio & Video
Ford 3000 traffic radio
your code is: 5194
Goodluck, Andre.
Aug 24, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
