Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Drivers won't install - can't print
I have just installed the software for this printer but I get the message that set up can't be completed because of insufficient internal resource or for an unknown error
  • Jane1961 Mar 29, 2008
    Tried that but it didn't work - still getting the same messages - insufficient resource and your hardware may not work.
    Thanks for trying.
    Jane
  • 27 Answers
Are u installing it by a cd ...........if so check it if there is any scratches or just download the driver from the net
Posted on Mar 29, 2008
SOURCE:
Set up wifi printing. Why am I unable to print documents?
you have to uninstall all other printer software except the epson printer software.after uninstalling all other printer software you have to restart computer
Sep 03, 2015 | Epson Expression Home XP-205 -...
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
I have my lexmark multifonction ,i install it normally in windows 7 64 bit, i can print normally but i can not scan document please i need your help when i scan a document i receive this message unable to...
Please download and install the scan drivers on your computer from support.lexmark.com website. Make sure to properly filter the operating system and then click on the downloads tab, you may select the link under drivers "Complete drivers and software for setting up, configuring, and using your device" when you install you may customize and select the local scan drivers.
For further assistance, please contact Lexmark Technical Support.
Jul 18, 2011 | Lexmark X543dn Laser Color All-In-One...
Installing HP4795 printers in Windows XP. During install XP cannot find print drivers. Can you tell me how to point install to the print drivers?
Click on the link below to download the Printer Drivers and later install them.
Download Link
After you download the file, run the file to start installation and complete the installation.
Disconnect the Printer cable before the installation starts and connect it when asked to.
If for any reasons, it does not recognize the printer connected, complete the installation by clicking on the option ( I will connect the printer later ) and complete the installation.
Then Click on the Diagnostic download option below to run the diagnostic tool to diagnose the issue.
HP Print Diagnostic Tool
My Suggestion would be to completely uninstall the software and reinstall it using the Download Drivers option above in this solution.
Thank you for contacting FixYa
Regards,
Ron
Dec 23, 2010 | HP C4795 AllInOne InkJet Printer
How to insttroal print drivers
Insert the printer software to the cd drive and the software will detect your printer connecting to your pc and it will ask you to start installing the software. Just click the icon install and it will run the installation. Note that if you are using parallel port and directly attached to your computer, you can immediately print after the installation is finish. But if you are using USB port, sometimes it require USB driver before the printer is working (there will be a message saying printer not detected). For network printer set up. you need the same installtion plus need to configure the printer network setting before printing.
Nov 23, 2010 | Lexmark E250dn Laser Printer
Can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
My office jet G85 has the message "remove and check color
Check and make sure you drivers are up to date. You may need to un-install the printer software and remove the printer in the control panel. Then reboot the computer,install the software(check and see if there is updated software if so download it).Then install the software and usually gives you instructions on when to connect the printer and drivers should be installed by software. Also make sure that when you use the print screen that you have the default printer selected and that the office jet is the default printer. It may be set to print to Microsoft one note for example.
Sep 05, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Cant instal the printer to mi computer
Setting up or installing a printer in Microsoft Windows. Issue:Setting up or installing a printer in Microsoft Windows.
Solution:There are two different methods a user can install a printer in Microsoft Windows. Below is additional information about each of these methods listed in the order we believe a user should try installing their printer in Microsoft Windows.
Before being able to install your printer you must have the software that was included with the printer. If you've lost the software for your printer you can download the drivers for your printer and use the drivers to install your printer. A listing of printer manufacturers and links to their associated drivers pages can be found on our printer drivers page.
Setup a printer using printer software
Every printer should come with the software used to install a printer in Windows. Although not all installations are the same the steps for installing this software should be similar to the below steps.
  1. Connect the printer to the computer and a power outlet and make sure it's on.
  2. Insert the CD that was included with the printer. If the CD does not automatically start the install program open My Computer, double-click on the CD drive, and then the Setup or Install file.
  3. Follow the installation wizard and your printer and its associated software should be installed successfully.
Installing a printer only using the drivers
In addition to the above steps a users can install a printer in Windows only using the printer drivers. This is recommended if you only want the printer to be installed but not the additional printer software programs that are often included with the installation and/or you've download drivers.
A listing of printer drivers and software downloads can be found through our printer drivers page.
Note: if you've installed the printer doing the above steps these steps should not be necessary unless you encountered errors.
  2. Click Start, Settings, and Control Panel.
  3. In the control panel double-click the Printers or Printers and Fax icon.
  4. In the Printers window click the Add a printer icon.
  5. After completing the above steps the Windows Printer Wizard will appear. Click Next, to start the wizard.
  6. Windows will prompt you if you're installing a Local or Network printer. If the printer is connected to your computer choose Local printer attached to this computer and click Next.
  7. When prompted for the location of the drivers for the printer. Browse the computer to the directory of your drivers or point it to the CD that was included with your printer.
Testing the printer
After the printer has been installed in Windows you can use Windows to print a self-test page to make sure the printer is working by following the below steps.
Microsoft Windows 98, 2000, ME, XP, 2003, and Vista users
  1. Click Start, Settings, and open Control Panel.
  2. Double-click the Printers or Printers and Fax icon.
  3. Right-click on the Printer you wish to test and click Properties. If you do not see your printer listed your printer is not installed. Seedocument CH000939 for additional information about installing a printer in Windows.
  4. In the Printers Properties window click the Print Test Page button.
  5. If the printer is able to print a test page, you're printer is installed and setup properly. However, if you're unable to print in other programs it's possible that the program you're attempting to print from has issues.
Mar 23, 2009 | Office Equipment & Supplies
HP Deskjet 840c - Printing Emails
I did see you reinstalled your software) but please continue
It is important that you have that icon by the clock. Power off the printer by pressing the power button on the printer.
Please un-install your printer software through Add/Remove Programs within the control panel. Please restart the Pc after un-install is complete. Create a folder on your hard drive and name it, "HP DeskJet 840C". Go to this link listed below & download the printer driver software listed. When you save to disk you can choose where you want to save. Pick the folder you created. Save inside this folder. The HP driver (Will most likely be updated software). I promise, you will have a icon down by your clock when finished.
http://h10025.www1.hp.com/ewfrf/wc/product?product=59868&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7&lang=en&cc=us
Follow the instruction in your manual for setup & installation.
If you using Outlook Express & you want to print or send through your printer the page should be set as 8.5x11". Orientation should be set to Portrait, unless you set this for A4.
Lastly, please turn off your anti-virus software during install & re-install. Just in case you come back to this thread!
please vote...
Jan 30, 2008 | Computers & Internet
Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Nov 09, 2007 | Epson Stylus Photo R1800 InkJet Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
35 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
