I HAVE AN AIRLINK 101 SUER g WIRLESS ROUTER. I want to set it so a password is required every time you go onto the internet how do i do this
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
  • Open your Web Browser enter the IP Address of the Access Point (default: 192.168.1.250) in the Address Bar and press Enter. (if you are not able to connect into the router wireless, you will need to connect directly into it through an Ethernet cable long enough to follow the set up instructions. Direct Ethernet connections to the router will not require use of a log-on password however you will still need to use the default passwords to access the routers internal settings)
  • Enter admin for both the User name and Password and click OK.
  • At the Wireless section, enter the SSID (SSID=Network name you can name your network whatever you want) of your wireless
    network and the channel number (for channel number use the default unless \you have problems)
  • At the Security Section, Select Enable and
    click on Configure Security.
  • FOR WEP - Select the level of WEP encryption (64-Bits / 128-Bits) you want to use on your wireless network (WEP is probably the easiest encryption for outsiders to hack. I recommend WPA-PSK)
  • FOR WEP CONTINUED: Enter the password for your wireless network in the Key 1
    field and click Save.
  • FOR WPA_PSK: Select WPA-PSK from the drop-down menu Leave the Algorithm set to TPIK and enter the password into the phrase field you want to use to provide access.The key should be 8~ 63 characters all inalphanumeric.Leave all other fields at their default. Click Save
  • Click Apply to save the changes.
All current Windows and Mac Operating Systems should immediately detect and identify your network SSID and prompt you for the password to access the wireless connection.
Hope this helps FixYa! Please take time to share the love and provide some positive feedback for this solution.
Thank you for using FixYa.com!
Posted on May 12, 2010
How do I set-up a password for my Airlink 101 Wireless Router Model 430W
I am assuming you are trying to create an administration password for the router. This is different to the security access code that wi-fi devices connecting to the router would need.
If you are unable to login to the router then follow the instructions to go to default setup as mentioned on this page.
AirLink101 Help Desk
Once you get to the administration page in the menu you can create a new password.
See manuals and other information about your router on this page. It may be important to know that this is a very old router and you may require a firmware upgrade to ensure it is compatible with current windows and browser versions.
Routers AR430W
Sep 28, 2014 | Computers & Internet
The password for my Airlink 101 AR430W says it's incorrect.
Try this http://www.fixya.com/support/r11153882-general_routers_reseting
Jan 29, 2012 | Airlink AR430W Wireless Router
Unable to access configuration utility webpage for an airlink 101 431w accesspoint.
Use an Ethernet cable to connect from one of the LAN ports on the router to the network port on your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG /RENEW
Press Enter
Look for output like: Default Gateway ... 192.168.1.234
Start Internet Explorer
Type http://192.168.1.234
Press Enter
Use the ID/password for the router to login to the router's web-interface.
Click to access the configuration wizards.
Jun 23, 2011 | Airlink 101 AP431W 108Mbps 802.11g...
How do I set this router up with AT&T Internet?
Hi Friend,
Make sure that you have connected all the wires/cables to their respective ports/places. Please follow the steps:
1.Open web browser and type 192.168.1.1 and hit enter.
2.Enter admin as username and password.
3.Select the proper region.
For cable modem:
* For most cable modem users, you should be able to connect to the Internet without any
configuration. If your ISP has provided you with a host name, enter it in the optional Host
Name field.
* If your ISP requires a registered MAC Address, click on the Clone MAC Address button.
Click Apply and OK to save the setting.
* Go to Status tab, Internet connection section to verify if you get the valid IP address
information.
For DSL:
* Select PPPoE from the drop-down menu.
* Enter your username and password provided by your ISP.
Click Apply and OK to save the setting. Go to Status tab, Internet connection section to verify if you get the valid IP address information.
4.Click Wirless (to configure wireless settings).
SSID: Any name as per your choice.
Operating Mode: Infrastructure
Authentication: Open System
Channel #: 6
WEP: Enabled and type any ten digit number as your password. You can use this password whenever you try to connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 08, 2010 | Airlink AR430W Wireless Router
Airlink router 101 can't connect 2 devices
this is a Dlink software bloqued, need to reset( push the reset buton more than 10 sec) the router, and config again. Caution change all router passw every 30 days or less.
Dec 26, 2009 | D-Link DIR-615 Wireless Router
Need password or paascode
addy is http://192.168.0.1
no user name
password = PASSWORD
Apr 12, 2009 | Airlink Computers & Internet
Can't block url's domains on Airlink 101 router AR680W
You need to update the firmware of your router for this feature to work.
Apr 01, 2009 | Airlink AR430W Wireless Router
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
