Question about Furuno 1715 7" Monochrome Lcd 2.2kw Radar Model#1715
Like a previous poster, I get "no heading pulse." However, my array is spinning, but erratically. I'm also in Mexico, and would like to pick up repair parts in the US rather than ship the unit to the US. Toothed wheel that is driving belt is sliding up motor shaft but I don't think that's the problem. What parts should I pick up?
    Scholar:
  • 157 Answers
Adjust the motor mounting so belt don't slide up and down including the tension. Check the cabling connections, axial position sensor and rotor for weather damage. if problem resolved seal the housing with a silicon gel. If belt has visual wear 80% chance thats your culprit. Please be very careful for the magnetron has very HIGH VOLTAGE.
Posted on May 13, 2010
2003 Ford Focus Error code PO320
P0320 - Ignition Engine Speed Input Circuit Malfunction The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred.
  • Loose wires/connectors.
  • Arcing secondary ignition components (coil, wires and plugs)
  • On board transmitter (2-way radio)
The DTC indicates that two successive erratic PIP pulses occurred.
Oct 28, 2016 | Ford Cars & Trucks
ERATIC INJECTOR PULSE NO START
You describe an electrical issue. First of all, how do you know the injector pulse is 'erratic'?
Is the ignition spark ALSO erratic? If so, how so? I need specifics, details regarding your description of 'erratic'. I can assume/presume you have experience/education/training in automotive diagnostics... ??
In my electrical/eagelectronics experience, you definitely have an electrical/electrodynamic problem/issue.
Tell me what you've done, diagnostically, to determine (isolate) the 'CAUSE' of this erratic injector pulse. What have you inspected/checked? What have you NOT inspected/checked?
Get back to me, then we can go from there.
However, first thoughts
The engine management computer (ECM/ECU/PCM) can cause/create the symptom you describe
The engine wiring harness also (chafed wires, bad ground circuits, etc.)
Malfunctioning senors (Crank Position Sensor (CKP), Cam Position Sensor (CPS),
Low Voltage Condition, etc.
Feb 08, 2011 | Hyundai Tiburon Cars & Trucks
1995 windstar says it has a po320 code. how t5o fix.
P0320 Ignition Engine Speed Input Circuit Malfunction-The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred.
Feb 05, 2011 | Ford Windstar Cars & Trucks
No heading pulse
Open the dome cover and check the belt that spins the array. Sometimes the gear on the motor that holds the belt comes loose and will not spin the array. I have seen this on 4 radars and all were about the same age. The gear has a small allen head set screw. Move the gear down and tighten the screw down. If you are still having issues there are some more troubleshooting techniques you can do, but you will need a multimeter to test voltages coming from the display.
Jun 04, 2010 | Furuno 1623 Radar 16nm Range
I have a kelvinator excellence 6.5 smartdrive9 top loader.The 3rd led,shortwash led,spin led and the one before the spin led is on and beeping. The machine will not fill and pulses in short bursts then...
your machine is a fisher and paykel, just re-badged. now the fault you have is your " OUT OF BALANCE" switch is faulty, probably due to corrosion . the switch is located under the control module which is under your display panel. if you choose i can guide you thru the repair. please reply 4 further help
May 29, 2010 | Washing Machines
Furuno 1715 gives "no heading pulse" error. Image normal, but clocked due to no reference. Pulled heading sensor (4X6X1mm black box, two wires, labeled NRS-101) and checked continuity across leads. Open...
Heading pulse is a reed switch sensor built inside the dome. upon each rotation of the array the reed switch is activated. Do a visual inspection of your array (inside) to make sure it is spinning (verify from a distance). Don't get eye level with the rotating array it can cause great harm to your eyes. Normally I have seen the belt slip off and also the lanyard attachment get caught in the array. Check those two things as well.
Mar 06, 2010 | Furuno 1715 LCD Radar System GPS Receiver
Can i feed 8 1/2 inch x 11 inch poster weight paper into my 3030?
Poster weight is too heavy for this machine, when paper is picked up it has to curl around the rollers in the back and do a complete turn-around. poster weight will just jam at the first turn.
Aug 07, 2009 | HP LaserJet 3030 All-In-One Printer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Raymarine 41xx - Message "bearing pulse error"
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Apr 28, 2008 | JRC 1500 MKII Radar
Furuno 1715 7" Monochrome Lcd 2.2kw Radar Model#1715 Logo
82 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
