Question about Vizio VW42LF 42 in. LCD HDTV
TV powers up. I get the backlite, then about 1 second of the blue box in the upper right hand corner that shows the input and channel. Then the screen goes blank but the sound continues to work. I have tried different inputs (which is hard to do without a picture) and according to the "blue" box info at power-up, I should have had them, but in all cases, sound only. Any ideas?
  • 87 Answers
Inverter probably bad.
Posted on May 12, 2010
I pressed a button by mistake and my Sony tv has no picture. Now has small box left hand upper corner with A and lines like wifi icon
Try the RETURN button on the remote to get back to viewing.
Get the manual at Sony KDL 40S2010 Manuals See page 11 for remote control keys and page 38 for further trouble shooting if necessary
Jun 03, 2016 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Nov 02, 2008 | Sharp LC-32SB24U 32 in. LCD TV
Screen blanks out int when on local channels
I had the same problem (a flashing HDMI 1 text box in the upper left hand corner of the screen every +/- 10 seconds) and rebooting the cable box seemed to help. I'd previously tried disconnecting and reconnecting the cables, but wasn't successful. I assume my problem originates with Time Warner Cable.
Jan 29, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony kv-32s42 needs help.Tuner problems?
Hi Grasshoppa, I would venture a guess that your tuner is not at fault but most probably the logic circuits controlling it since as you posted, you can tune > get a good picture but "channel numbers in the upper right hand corner ...." If your intention is to use the VCR and thereafter change channel using the VCR, you may use the Audio/Video input. With an RCA 3 cable connector, connect the (Yellow) Video out, (Red/White) L/R Audio out of the VCR to the Video in &L/R Audio in of the TV. You don't need to set the TV to Ch 3 but rather select Video 1 or 2 or A/V. Hope this be of some help/idea to you. Post back how things are or should you need further information. Good luck and kind regards
Jul 27, 2007 | Sony KV-32S42 32" TV
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
Apr 23, 2007 | Panasonic CT-36SL13 32" TV
Vizio VW42LF 42 in. LCD HDTV Logo
161 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
