Question about Samsung TV Remote Control
Buttons not working
Source button is transmitting to the TV but doesn't make any changes. Volume buttons doesn't work at all. All other buttons work ok.
Samsung BN59-00516A
3 Suggested Answers
SOURCE: My samsung remote...model #BN59-00599A is
try removing the batteries and pressing every button one at a time. If it still fails to work contact remotes.com
Posted on Nov 26, 2008
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
Tv volume and input not working
The button itself may not be making contact with the circuit board under it
Feb 14, 2016 | Insignia 42" LCD Flat-Panel HDTV
Remote control stopped working changed batteries and still not working
Here are a few suggestions to help you with this problem:
It is possible that the battery contacts are corroded so you might try expecting the contacts and cleaning them. Since you cannot see if the IR signal is being sent, you can use another IR remote that you know works and see if you can Jam the signal of the working remote with your Hql-260wr remote. To do this, push the volume up button on the TV remote and hold it down while at the same time using the known working remote to control its companion product. If the working unit stops responding correctly when the volume button is pressed, it is transmitting an IR signal.
In this case, since you confirmed that the remote is transmitting, you can make sure that you are on the correct device settings for the remote. If you select the TV setting for instance, see if the remote now can control the TV. The main functions to try first are volume and channel buttons.
If this does not work, you will need to find out where the IR receiver is on the TV and make sure that the receiver lens is not blocked by something such as another device like a video console, etc.
Apr 03, 2015 | Televison & Video
My Channel Up button is stuck changing the channel. How do I fix it
Is this on the remote? On the TV?
If it is the remote, replace it.
Mar 30, 2014 | Westinghouse Televison & Video
My UN40D6400 remote doesn't work
look carefully in the manual to see if it has a lock out where all or most buttons do not work--also the remote can be tested--every button--testers are common and also a digital camera in a dark room will react when remote is pointed at it and buttons pressed--flash on camera screen--either the remote or likely the set has it locked out in some way.
Apr 24, 2012 | Samsung 40 UN40D6400 3D LCD TV
THE VOLUME DOESN'T WORK ON MY SAMSUNG PLASMA TV! ONLY WHEN IT'S ON TV! WHEN I PUSH THE SOURCE BUTTON AND CHANGE IT TO DVD THE VOLUME WORKS JUST FINE!
if you are using some device like digital box you should try to check the cables connecting your unit specially the audio cables.
Jul 05, 2011 | Televison & Video
Hi, remote not working and unable to change channels using tv buttons. other buttons on tv - volume etc are working fine
if your remote is for cable, then you have to push the cable button, then change channels. volume will work only on tv mode.
Oct 06, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
ILO'26HD got stuck, its freezed
Yes, Walmart sells ILO, I would not buy that brand. Anyway I am not familiar with the model of the tv, but it should have buttons on the front bottom or right side of the tv so you can change the source and change the volume. So my questions, does anything on the remote work? Do the buttons on the tv work? The DirectTV should not be interfering. It was working fine, correct?
Aug 14, 2008 | iLO 2600 Television
Hyundai 32" tft lcd tv. model no.hlt 3270
I don't know if these codes will work but the Hyundai ones we use are code 1272 or 0662.
To put the code in:
Press TV
Press and hold Select & Red until the LED blinks twice
Put in the first code above
press Select
then try the volume buttons, if that doesn't work do exactly the same sequence but try the second code, if neither work let me know and I'll try and find another code for you
Jul 30, 2008 | Hyundai HPT-4250 Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Samsung TV Remote Control Logo
286 people viewed this question
Jerry Greenberg
Jerry Greenberg
